Samsung S9 USB-C to HDMI signal problems
Mason Denysek
on Mar 21, 2018 at 6:09:05 am
I’m trying to run a Samsung S9 cellphone through a LUT box via HDMI. I used a USB-C to HDMI adapter to get a mirrored image of the phone - which works great plugged straight into a monitor (Sony OLED PVMA250). The LUT box on the other hand does not pick up the signal. Sometimes the video status on the COLR will flicker between “no video” and “1080/60p” but nothing will show up on the monitor at all. Could the phone be outputting a variable frame rate and that is why it is not working? Would this explain the flickering signal? Is there a solution to this? I have been looking into potential converters but have not found any solutions yet. Also - will I have the same issues when transmitting the signal through a teradek bolt?
