Quality Enhancement !
Justin Burkhardt
on Jan 25, 2018 at 4:30:51 pm
Good morning,
I have an old video that is poor quality. 25fps. 160x112. Very small and pixelated/blocky.
When I enlarge, it of course just gets worse.
I have tried some different converters using deblocks etc, but nothing seems to work. I have also tried to clean it up in Adobe Premiere with no luck.
Any suggestions?
Thanks in advance
Ivan Phang
Re: Quality Enhancement !
on Aug 2, 2018 at 8:41:27 am
Unfortunately, you just can't fix something that has nothing for you to fix. The only alternative will be to recreate it.
Helping clients attract Eyeballs!
https://luciddream-animation.com
Ronald Lindeboom
on Aug 26, 2018 at 4:32:01 am
Starting with 160x112, as Ivan Phang points out, there is absolutely nothing there that can be rescued. I believe the technical term is that you are hosed. You will have to start from scratch.
Ron Lindeboom
