Hd sdi to displayport converter
shinoj Krishnan
on Oct 21, 2017 at 8:46:22 am
Hello everyone,
Could anyone suggest a converter which does hd sdi to displayport?
Input 1080i 50
I checked with apantac anf it does only 4x3G sdi to 4K (UHD)
Thanks guys..at the moment i achieve it by sdi to hdmi and then hdmi to dp.
Jeff Pulera
Re: Hd sdi to displayport converter
on Oct 31, 2017 at 2:06:34 pm
I don't believe you will find such a device. Continue using SDI to HDMI to DP.
The converter manufacturers are all tooled up for conversion to HDMI as HDMI is so common. They are not going to add an additional model when HDMI is easily converted to DP for the few that need it.
Jeff Pulera
Safe Harbor Computers
Leroy Lucas
on Jan 26, 2018 at 1:08:41 am
The demand for something like that is low as Jeff said.
