producing a DCP with openDCP
Diederick Fokker
on Aug 8, 2014 at 8:33:04 am
HI,
I am using OpenDCP to produce a DCP from a 92 min doco edited in FCP7.
1. My 1280x720 sits in a 1920x1080 project (150%)in FCP.
My aspect ratio is reduced (Top&bottom letterbox) to scale to cinemascope (2,4:1)
and I want to finalize for 2K.
How do I export the image sequence (Tiff):
1. As for a standard 2kDCP, so 2048x1080 (black bar top&bottom)
2. As 2048x 858 (only the active pixels)?
Second question:
I don't seem to get a valid .WAV(E) export from either FCP7 or Soundtrack Pro to input into OpenDCP.
settings are 24bit 48kHz uncompressed
Anyone any experience with this? Thanks
XDCam fullHD, FCP 3 screen editsuite
Terrence Meiczinger
Re: producing a DCP with openDCP
on Aug 9, 2014 at 6:05:00 pm
1. You can scale your project to 1920x1080 and create a flat 2k DCP.
2. Use a separate mono 24-bit 48khz wav file for each channel.
Diederick Fokker
on Aug 12, 2014 at 12:15:41 pm
Thanks you. It worked with 2048x858 as well. regards Diederick fokker
