Mac Pro (OSX) to a simple SONY RGB monitor
Ivars Bezdechi
on Dec 26, 2012 at 10:11:57 am
I have a Mac Pro (2x2.66 GHz Dual-Core Intel Xeon) which right now connects to a simple SONY 8041Q video monitor through a DVCAM unit (RCA to BNC adapters)
In order to view the output from my Mac to the SONY monitor (how it prints to video), I send the video via Firewire to a DVCAM unit from my Mac.
I have standard DVI video outputs to my two Mac monitors.
How can I view video from my Mac to the SONY monitor without having to go to the DVCAM unit? Perhaps a USB video card to RCA video....or USB video card from DVI to RCA?
Ideas? Bueller?
Ivars
San Diego, CA
http://www.paulkruzelive.com
http://www.artlinemedia.com
David Eaks
Re: Mac Pro (OSX) to a simple SONY RGB monitor
on Dec 26, 2012 at 10:44:35 am
Monitor video from what, FCP 7? How about a Matrox MXO2 Mini or LE, with component video to the monitor? You'll also have the option to use any TV with HDMI as a monitor and with the LE you get SDI as well.
I have used the video output from FCPs "print to video" through MXO2's many times without issue.
Ivars Bezdechi
on Dec 26, 2012 at 10:57:03 am
Yes....FInal Cut Pro and Premiere and After Effects......
David Eaks
on Dec 26, 2012 at 11:32:48 am
Well, some I/O device like Matrox and AJAs offerings should be just what you need. Excellent Capture, Monitor and Output, both with up/down/cross conversion.
I just double checked, and there are new Matrox drivers out that support:
"Matrox MXO2 Mini with MAX v2.6 (build 23) software for Mac OS X Mountain Lion (10.8.2) and Lion (10.7.5). This software supports Apple Final Cut Pro 7.0.3, Adobe Premiere Pro 5.5.2, Apple Compressor 3.5.3 and 4.0.5, Adobe Media Encoder 5.5.1, and Avid Media Composer 5.5.3."
...finally a unified driver for "the three As". You used to have to uninstall drivers/reboot/install other drivers/reboot between Apple, Adobe or Avid. If this version doesn't match your OS and APP versions, Matrox has a nice archive of past drivers available.
Gary Bettan
on Dec 26, 2012 at 2:36:10 pm
MAtrox MXO2 Mini MAX is a great choice for you! http://www.videoguys.com/Item/Matrox+MXO2+Mini+MAX+Desktop+Kit/44F28514D494...
Don’t settle for an HDMI and analog I/O card with messy cables when you can get all the features and more in a professional breakout box with Matrox MXO2 Mini. This sleek little device for Mac and PC also gives you the added advantage of portability. You can take it with you wherever you go. Use it with a laptop or a desktop system and your favorite applications including Final Cut Pro, Adobe Premiere Pro and Photoshop, and many more. Capture and playback high definition video via HDMI and analog component; or NTSC and PAL via analog component, S-Video, and composite. Convert your standard definition videos to high definition, or vice versa, while capturing or playing out, using Matrox MXO2 Mini’s high-quality dedicated hardware. Turn your HDMI screen into a professional-grade video monitor with Matrox’s unique color calibration tool. Easily edit AVCHD footage by capturing into an edit-friendly compressed or uncompressed format. Count on uncompromising Matrox quality and reliability in MXO2 Mini, backed by a three-year warranty.
Affordable high definition HDMI and analog I/O for Mac and PC
Matrox MXO2 Mini is also available with Matrox MAX technology for faster than realtime high definition H.264 file creation.
Matrox MAX is a unique technology that implements faster than realtime H.264 encoding for resolutions ranging from iPod to HD. It uses a dedicated hardware processor to accelerate the creation of H.264 files for Blu-ray, the web, and mobile devices. By using specialized hardware acceleration, jobs are finished with amazing speed and system resources are liberated for other tasks. Quality and flexibility are ensured through direct integration with professional applications such as Apple Compressor on the Mac and Adobe Media Encoder on the PC. As an added benefit, the Matrox MAX technology allows direct export to higher-quality H.264 Blu-ray compliant files from Compressor.
Gary
COW members get 5% OFF with Coupon COW5OFF
http://www.videoguys.com 800 323-2325 | We are the video editing and production experts!
