Subtitles Workflow
Drew Umland
Subtitles Workflow
on Nov 25, 2012 at 10:24:23 pm
Long time reader, first time poster. I have been requested to do something that I am not at all familiar with, merge SRT files to h264 MP4 files for 10 feature length films.
It sounds simple enough, but does anyone have any suggestions for workflow, software to use or estimations on how long it takes to do?
Thanks in advance.
- D
Zach Powers
Re: Subtitles Workflow
on Nov 26, 2012 at 8:34:11 pm
Are you trying to hard code the subtitles (i.e. add them to the image)? Or are you trying to add subtitle tracks that a viewer can turn on and off like DVD or Blu-ray subtitles?
If it's the latter, that's tricky. If it's the former, there are a lot of good tools available. If you are working in Creative Suite, pt_Import_Subtitles is a great tool that works through After Effects. The only limitation I've found is that is chokes on subtitle text files (I use SubRip files) larger than 2MB, so you have to split up the subtitles for import. If you need to convert your files to SubRip or Encore for pt_Import_Subtitles, SubtitleEdit is a great freeware application for this.
I have also tried out hard-coding with VirtualDub. It works pretty well, and you could make an intermediate file with the hard-coded subtitles using a lossless codec like UT or Lagarith. You could then send the intermediate file to your encoder to make the H.264 file.
