Multiple Video playback through a projector (software)
Rich Eames
on Oct 25, 2012 at 4:33:47 pm
I'm trying to see if something like this exists.
An application that has "drop zones" that I can move around or size - triange, circle square etc and have the ability to drag and drop a video file and have it play / loop until I drag in a new clip.
For example:
Projector to screen: upper left rectangle shape, upper right triangle, lower left oval, lower right star
Any area that doesn't have a "cookie cutter" effect is black so projector sends no image.
Then as the play starts drag into rectangle drop zone a loop of clouds - the right side gets a cityscape these proceed to change as the play goes on.
It would be great if you can dissolve between images in the same window but the player would be great to start with.
I know I can time a 90 minute video but this is live and they may not hit all the marks at the right moment during each performance.
Rich
