DIY8 System Case
Winston David
DIY8 System Case
on Feb 20, 2012 at 11:49:13 pm
I'm thinking about putting together a system based on the DIY8 Sandy bridge specs and had a question about the Antec 902V3 case paired with the Asus P8Z68-V Pro motherboard. This motherboard has two FireWire ports, available through two headers on the motherboard. So, if you plan to use them, you will need to either buy an adapter or buy a case with two FireWire ports. The Antec 902 case does not have firewire ports. I suppose I could also use a separate firewire card, but then I'm not taking advantage of everything the motherboard has to offer. Wouldn't it be better to just buy a case with a firewire port? How did Videoguys make use of the Firewire with the Antec 902 case?
