DIY8 Build
The Dive
DIY8 Build
on Mar 10, 2011 at 10:26:05 am
Hi there
Have just built the DIY 8 as below..
Just a query re HDD config. Have currently got 2 x 600Gb in RAID0 config on the 2 SATA6 ports for video & 300Gb on one of the SATA3 ports for o/s..
Is this the best configuration.. Or something different.?
Am also looking at a 32Gb SDD for separate paging file.
Would appreciate any advice.
Many thanks
Win 7 Pro 64bit
CS5 Prod Suite
ASUS P6X58D-E
Intel Core i7 970
Prolimatech Megahalems Rev. B CPU Cooler
Memory 1 Corsair CMX6GX3M3A1600C9 6GB (3x2GB)
Memory 2 Corsair CMX6GX3M3A1600C9 6GB (3x2GB)
HDD 1 WD VelociRaptor 300GB 10KRPM SATAII
HDD 2 WD VelociRaptor 600GB 10KRPM SATAIII
HDD 3 WD VelociRaptor 600GB 10KRPM SATAIII
GeForce GTX470
LG BH10LS30 10X Blu-Ray Writer
Seasonic M12D 850W 80Plus PSU
CoolerMaster HAF 912 Plus Tower
Jcschild
Re: DIY8 Build
on Mar 10, 2011 at 1:59:06 pm
ideally you have 2 sets raid 0 plus OS.
you do not want to read and write from the same drive array (unless doing a large (8+ drive) raid 5)
so you have 1 set for media 1 set for export/final render...
Scott
ADK
The Dive
Re: DIY8 Build
on Mar 10, 2011 at 6:56:14 pm
Cheers Scott
Good advise.. But also wondering about the RAID0 or o/s best being on the SATA6 connections..?
Thanks Guy
Evan Newsome
Re: DIY8 Build
on Mar 13, 2011 at 3:09:01 pm
SATA6 is more for Solid State Drives. So in the end the drives you mentioned don't really matter if it is connected to a SATA6 or SATA3 port. The HDD is not fast enough to max out bandwidth capability of the port.
to my knowledge
Jcschild
Re: DIY8 Build
on Mar 21, 2011 at 12:26:31 pm
+1 pretty much what Lee said
the only time it matters is if on a good controller. and even then not much.
on the other hand if buying new drives you do want to buy Sata 600
more important is the 64meg cache.
Scott
The Dive
Re: DIY8 Build
on Mar 30, 2011 at 7:26:37 am
Thanks for those comments guys..!
Have now added the following:
2 x WD Caviar Black 500GB 32MB 7200rpm SATA3 in RAID0 for output renders and media cache.
1 x Adata 2.5 SATA II S596 Turbo SSD 32GB for page file and ReadyBoost.
Does the Win7 Readyboost function work in conjunction with the pagefile or is it best to have one or other..?
Many thanks..
Cheers
Guy
