GTX 480 not working
saftsuse
GTX 480 not working
on Feb 17, 2011 at 6:44:11 pm
I bought the parts as described here http://videoguys.forumexperts.com/viewtopic.php?t=113951
Only change is that I bought an SSD instead of the raptor.
And as soon as I install the driver for the GTX 480 card, the computer will not boot up.
I googled it. and there seeme to be many others with the same problem.
So I recommend to Not buy this card, or at least know what you might get into.
See this link for an description of the problem : http://forums.nvidia.com/index.php?showtopic=171920&st=0
Edit : changed from GTX card to ATX Smile
Edit II : Changed it back to GTX - I should not post when I'm to sleepy Surprised ops:
Jcschild
Re: GTX 480 not working
on Feb 18, 2011 at 3:11:10 pm
i have never seen an issue with the 480 card.
or 460, 470, 570, 580.
sounds like an issue with your bios setting most likely memory
Scott
ADK
saftsuse
on Feb 18, 2011 at 7:59:44 pm
Jcschild: i have never seen an issue with the 480 card.
Scott
ADK
I can of course try, but how can I find out if there is a problem with Bios / memory?
But I still think I just ran out of luck with compability with the Asus mobo and the 480.
There is a this thread over at the Nvidia forums.
Just called "Welcome to the club" of owners with 4xx cards that do not work.
http://forums.nvidia.com/index.php?showtopic=187401&st=0
Just have a look, it is well explained in the first few lines of the first post.
There's a lot of people that have just the same problem as I have.
They tried to change mobo, bios, power, taking out memory, replacing etc, just about eveerything. But the computer still don't boot past the welcome screen / black screen.
But the same card will work on other computers, not just the one they build.
I'm sending the 480 back, and have to try an another card ( Not 480 Evil or Very Mad )
Is there any other card besides the 480, that will work well with Vegas pro and / or Premiere ?
Erik
Jcschild
on Feb 19, 2011 at 4:58:47 pm
interesting read..
based on the "C states" comment it again makes me believe its a Motherboard bios issue.
we turn off all C states in the bios turbo can be a real PITA. as can all the sleep states
while this is only 1 of our tricks for a succesful edting system and we do many more
i would start there.
honestly i ship over 1000 systems a yr 90% have nVidia cards
i have never seen this issue and i sell a lot of 460,470, 570, 480, 580
i even asked my head tech and he said the same thing.. bios/memory settings
Scott
ADK
saftsuse
on Feb 20, 2011 at 11:52:59 am
Thanks for trying to help me.
I tried to look in the Bios, but since I do not know too much about whats going on in there I did not take the chance to change anything.
Tried some other stuff too, reinstalling etc. but to no avail.
So then since I was about to return my 480 card, I was looking for a new card.
And this time I search the new model number and blackscreen.
And I found this one from anoter forum :
I had the supplier check the hardware and everything works fine. I have since established that the monitor is the culprit.
I tried my new computer with a new monitor and everything is fine. However, if I boot the computer with my old monitor (Fujitsu 17" Sep2005) I get the blank screen. The funny thing is that if I boot the computer with the new monitor (LG 22" Jul2009) and then switch the cable to the old monitor, it works. After a reboot on the old monitor I get the blank screen again.
Since I have only borrowed the new monitor and I don't want to buy one, I would really like to fix this problem. It just doesn't sound logical to me that a monitor should not work with certain OS or hardware setups. I know it has something to do with the refresh rate but I can't put my finger on it.
So I tried to disconnect my BenQ LED EW2420, started the computer.
Waited for a minute, connected the screen.
And voila, everything is working. Nvidia drivers are innstalled and resolution is 1920*1080
Only difference from the poster is that I can reboot with the screen connected. Very Happy
So lets see if it will continue to work the next few months. Very Happy
This was a strange solution to my problem.....
Thanks again Very Happy
