Video Card/Hardware recommendation
ajaysandhir
on Nov 23, 2010 at 10:05:56 am
Hi!
I am looking for Video Card/Hardware recommendation which serves the following 2 purposes:
1) Capture High Definition content & stream it over web (using Windows Media Encoder)
2) Play out streaming content off the Web (through Windows Media Player) and display it over local display through a High definition Component video output.
Please note that the content mentioned in 1 & 2 are independent and both needs to be done simultaneously.
I was looking into the Matrox MXO2 Mini, but I am not able to figure out if it would server the application mentioned above. Would it only playout the content that is being captured or will I be able to play out content from my PC using a media player?
Your inputs are highly appreciated.
ajaysandhir
Re: Video Card/Hardware recommendation
on Nov 23, 2010 at 10:13:52 am
Both the input & output are through HD Component video.
