Plase comment on my sys config to run APPro CS5 smoothly -Th
Pushpanatha de Silva
on Sep 16, 2010 at 2:23:47 pm
Hi
Your (any) comments about following system is much appreciated. At present I am experiencing choppy video(draft quality video on monitor) and slowing the process on my Dell Dimension 8400(Pentium4/3.4GHz,2GB DDR2 RAM, 500GB HDD)when running Adobe PPro CS4. Video Camera used Sony PMW EX1 with Sony SXS memory cards.
The system I am intend to buy is mainly to run the APPRo CS5 initially and later associated Adobe Master Collection programs( Eg. Fireworks, Dreamweaver, After Effects,Encore, Flash, Illustrator, Photoshop and Soundbooth).
Dell Precision T7500 (Workstationchassis with 1100watts power supply (85%+ Efficiency Power Factor Correcting power supply)
Intel Xeon E5630 2.53GHz, 12M Cache, 5.88GT/S QPI, Turbo, 4C
Intel 5520 chipset
Windows 7 Ultimate 64bit
Dell back-up and Rcovery Manager for Windows 7
24GB (6X4GB) DDR3 RDIMM Memory, 1333MHz, CC
600 GB (15000rpm) SAS HDD Drive(for C:)
Two 600GB (15000rpm) SAS HDDs
PRC6/i SAS/SATA Hardware RAID Card
SAS Connector cable
SATA Cable for 2nd Optical drive
All SAS Drivs, RAID 5, 3 drive XtremeMusic
Addiional Broadcom 5722 10/100/1000 Ethernet Networking LAN Solution
Dell MS 111 USB Optical Mouse
Dell QuietKey Keyboard
3yr on-site warranty
2 Monitors - 24" - Dell MOdel G2410H Widescreen Flatpanel monitor s
Integrated Intel SATA 3.0GB/S controller with support for RAID
Integrated Broadcom 5761 Gigabit ethernet controller
Integrated High Def Audio
Slots: All full length except as noted
1 PCI-e X16 Gen2 wired as X4
2 PCI-e X16 Gen 2 slots wired as X8 (one is half length)
2 PCI-e X16 Gen 2 Graphics slots
1 PCI-X 64bit/100MHz slot with support for 3.3v or univrsal card
1 PCI 32bit/33MHz 5v slot
Standard I/O ports
11 USB 2 (2 on front panel, 6 on back panel and 3 internal)
IEE 1394a (One front, one rear)
1 Serial
1 Parallel
2 PS/2
1 RJ 45
1 e-SATA port on back panel
Stereo LINE-IN and Headphone LINE-OUT on back panel
Microphone & Headphone connector on back panel
Bays:
4 Internal 3.5" HDD Bays
3 xternal 5.25" optical bays, one of which can accommodate a fifth HDD
1 xtrnal 3.5" flex bay for floppy driv or Media crd Reader
Total Weight 25Kg
Your help on comments for above system are much appreciated.
Thanks.
Jcschild
Re: Plase comment on my sys config to run APPro CS5 smoothly -Th
on Sep 17, 2010 at 1:13:36 pm
go to the Adobe forums and post this.
http://forums.adobe.com/community/premiere/hardware_forum
1) no Dell or HP.
2) unless you are buying Dual Xeons 2.93 or higher 12 core
you are far better off with a SINGLE 980x.
you dont mention your format so its hard to tell you.
AVCHD/XDCam/Red all need 2 sets raid 0 or higher. (especially Red)
minimum for CS5 is 12 gig with 24 gig being ideal DDR3 1600 is a better option.
Scott
ADK
on Sep 17, 2010 at 9:17:53 pm
Hi Jcschild
It's (Sony) XDCamera. using SXS mem cards
Why u say NO for Dell & HP. I have been using Dell since 1995. THere after sales service was very good for me in the past.
What do u think about the RAID 5 system with 3 600GB SAS HDD?
Thx for ur input for my qury.
