Video Card Hack?
wbriers
Video Card Hack?
on Jul 14, 2010 at 8:47:09 pm
I've read several posts about using GTX 480 or 295 GPU with a "hack"... so what hack is required to use these with CS5?
poppabear
The Hack with CS5
on Jul 16, 2010 at 5:10:37 pm
The hack allows any CUDA card to work with the MPE GPU acceleration.
Apparently, the video card should have at least 800M of video memory.
Here is the link in the Adobe Premiere Pro CS5 Discussion.
http://forums.adobe.com/thread/632143?start=0&tstart=0
I was able to get a EVGA GTX 275 to work.
Gary Bettan
Re: Video Card Hack?
on Jul 23, 2010 at 5:45:14 pm
here is the hack I've seen posted around the web on various forums.
How to make Premiere CS5 work with GTX 295
I figured out how to activate CUDA acceleration without a GTX 285 or Quadro... I'm pretty sure it should work with other 200 GPUs. Note that i'm using 2 monitors and there's a extra tweak to play with CUDA seamlessly with 2 monitors.
Here are the steps:
Step 1. Go to the Premiere CS5 installation folder.
Step 2. Find the file "GPUSniffer.exe" and run it in a command prompt (cmd.exe). You should see something like that:
Device: 00000000001D4208 has video RAM(MB): 896
Vendor string: NVIDIA Corporation
Renderer string: GeForce GTX 295/PCI/SSE2
Version string: 3.0.0
OpenGL version as determined by Extensionator...
OpenGL Version 2.0
Supports shaders!
Supports BGRA -> BGRA Shader
Supports VUYA Shader -> BGRA
Supports UYVY/YUYV ->BGRA Shader
Supports YUV 4:2:0 -> BGRA Shader
Testing for CUDA support...
Found 2 devices supporting CUDA.
CUDA Device # 0 properties -
CUDA device details:
Name: GeForce GTX 295 Compute capability: 1.3
Total Video Memory: 877MB
CUDA Device # 1 properties -
CUDA Device # 0 not choosen because it did not match the named list of cards
Completed shader test!
Internal return value: 7
If you look at the last line it says the CUDA device is not chosen because it's not in the named list of card. That's fine. Let's add it.
Step 3. Find the file: "cuda_supported_cards.txt" and edit it and add your card (take the name from the line: CUDA device details: Name: GeForce GTX 295 Compute capability: 1.3
So in my case the name to add is: GeForce GTX 295
Step 4. Save that file and we're almost ready.
Step 5. Go to your Nvidia Drivercontrol panel (im using the latest 197.45) under "Manage 3D Settings", Click "Add" and browse to your Premiere CS5 install directory and select the executable file: "Adobe Premiere Pro.exe"
Step 6. In the field "multi-display/mixed-GPU acceleration" switch from "multiple display performance mode" to "compatibilty performance mode"
Step 7. That's it. Boot Premiere and go to your project setting / general and activate CUDA
