DIY 7.x choice of ram
Igor
by
on May 25, 2010 at 11:59:45 pm
I'll be using an Asus P6 58D Premium with a Gulftown 6 core. Between Corsair Dominator (1600) and Dominator GT (1866) which would be the better choice? I read somewhere that the 12G GT set doesn't support Intel XMP. That's what's weighing against the faster ram in my mind. But other posts say that the GT ram does support XMP. I'm doing multicam HD with 4-6 streams. Would the difference in speed provide a significant benefit?
Evan Newsome
Re: DIY 7.x choice of ram
on May 26, 2010 at 2:47:47 am
Do you plan to over clock your RAM??
if your answer is no..... then the answer is neither.
standard Corsair XMS will work fine. My understanding that this 6 core chip uses DDR3-1066
If you plan to overclock I'd go with the 1600
my 2 cents
PS From tests I have seen it is an awesomely fast chip. I am just not sure if I would spend that money.
Personally, I am not sure what determines your ability to handle 4-6 streams.. and streams of what?? FULL HD @ what Mbps???
