New Build Input (DIY MAR10)
Peterbilt
on Mar 1, 2010 at 11:54:47 pm
I put this list of components together for my new machine. This would only be the second computer I've built, so I would really appreciate it anyone and everyone could look it over and comment if anything looks fishy. Also, please feel free to recommend different components.
I followed the DIY7.7 build fairly closely except for a different motherboard, which I'm a bit nervous about. But I wanted more than 6 SATAs. So please look closely at my motherboard choice.
This will be running the Adobe suite.
Motherboard: [url=http://www.newegg.com/Product/Product.aspx?Item=N82E16813128423]GIGABYTE GA-X58A-UD3R LGA 1366 Intel X58
Processor: [url=http://www.newegg.com/Product/Product.aspx?Item=N82E16819115225]Intel Core i7-930 2.8GHz LGA 1366 Quad-Core
RAM: [url=http://www.newegg.com/Product/Product.aspx?Item=N82E16820145235]CORSAIR XMS3 12GB (6 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
Boot Drive: [url=http://www.newegg.com/Product/Product.aspx?Item=N82E16822136284]1TB 3.0Gb/s WD Caviar Black (WD1001FALS)
Raid 0 Video Storage: [url=http://www.newegg.com/Product/Product.aspx?Item=N82E16822136284]2x 1TB 3.0Gb/s WD Caviar Black (WD1001FALS)
Misc/Final render Drive: [url=http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533]1TB 6.0Gb/s WD Caviar Black (WD1002FAEX)
GPU: [url=http://www.newegg.com/Product/Product.aspx?Item=N82E16814130339]EVGA 512-P3-N871-AR GeForce 9800 GTX+ 512MB 256-bit
Power Supply: [url=http://www.newegg.com/Product/Product.aspx?Item=N82E16817139009]CORSAIR CMPSU-850TX 850W
DVD Burners: [url=http://www.newegg.com/Product/Product.aspx?Item=N82E16827106289]2x LITE-ON CD/DVD Burner SATA (iHAS124-04)
Case: [url=http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160]COOLER MASTER HAF 932 RC-932-KKN1-GP ATX Full Tower
OS: [url=http://www.newegg.com/Product/Product.aspx?Item=N82E16832116758]Microsoft Windows 7 Professional 64-bit
Jcschild
Re: New Build Input (DIY MAR10)
on Mar 3, 2010 at 8:54:03 pm
for Adobe you want a Cuda Supported card. with CS5 coming out shortly and having the mercury engine which needs Cuda support
they are only supporting GTX285 and tehn higher quadros.
the 285 will outperform all quadros.
so buy one.
also get Mushkin ram the corsair is way over priced.
Scott
ADK
Evan Newsome
on Mar 8, 2010 at 12:02:08 am
Jcschild: for Adobe you want a Cuda Supported card. with CS5 coming out shortly and having the mercury engine which needs Cuda support
so buy one.
Scott
ADK
x2
I love the new looks & features of the new Gigabyte MOBO. My GA-EX58-UD4P works fine with CS4. report back!!! *Do note that the gigabyte SATA ports on my MOBO don't like certain CD/DVD/Bluray drives. I hope they fixed that issue with the "A" version MOBOs. If you have a problem, be sure to plug them into your Intel SATA ports and I suppose there is nothing wrong using the PATA port.
