Pro Audio
heyacapella
Pro Audio
on Jan 17, 2010 at 9:23:04 pm
hey videoguys,
i have a semi-pro audio production studio and am trying to do live recording of audio/video streams without post processing on a software platform
my video setup is consumer grade with analog composite video into a consumer grade stand alone dvd burner
my audio setup is sophisticated and i can feed in live high quality processed audio into my dvd burner as it's being recorded though have to be very careful to monitor VU sound levels so as to not get too weak of an audio signal while at the same time not clipping my audio at the peaks (this ruins the recorded audio) with too strong of a feed
i would like to upgrade to 720 (composite is 480 i think) and streamline my equipment so it's not so high maintenance tempermental
can you tell me what you sell that will allow me to record pro-audio onto a live streamed video feed without using post process video editing software - this assumes the audio stream coming in is already quality mixdown grade balanced
right now i have a rig with a composite video in, a pro-audio stereo in (two GE plugs), a video out connected to a color 19 inch video monitor (for both playback & live record monitoring), and a playback audio out which i have to mute during recording because of audio delays that my dvd burner inserts (about 60 millisonds, a noticable echo)
it's kind of a dog - though it works - there's got to be a better way
ideally less than $500 not including the camera, pro-audio system, and color monitor
TIA Smile
