Building a new system, i need advice...
liquid_snake_fox
on Nov 6, 2009 at 4:37:33 am
Hi every one, i'm into the video editing stuff. Currently, i have a P4 system, i love this system, but, just imagine my pain when i do renders, or work with After Effects... so i need something faster Wink
At last i have money, not so much, but here is the list of the new system
CPU Core i7 920
Motherboard GA-EX58-UD5 (maybe ASUS P6T)
HDD1 500GB (system drive)
HDD2 1TB
Video Radeon 4890 Vapor-X
RAM DDR3 4GB (Super Talent, but i don't know anything of this memories, i haven't heard of this trademark before)
I need advices, i'm all ears.
Alex Cantu
Re: Building a new system, i need advice...
on Nov 6, 2009 at 11:19:19 pm
Hi
Yoour configuration looks fine, just a few comments
- The mobo supports triple channel memory, get 6 GB of ram (6x1GB) to take advantage of this.
- Instead of a single drive for capture make an array 2x500 GB for better perfomance.
Feel free to ask.
Cheers
liquid_snake_fox
on Nov 8, 2009 at 3:29:58 am
Chipocludo:
why 6x1GB??? why not 3x2GB??? or something else... do i'll get better performance?
What mark of memory should i get???
And how many power do i need? i was thinking to get a 750W power supply
Alex Cantu
on Nov 9, 2009 at 8:56:58 pm
Hi
It's just an example of how u could set the memory, it depends on how much ram the mobo supports/ you can afford. But 6x1GB or 3x2GB would give the same performe but the allow future upgrades (6x2GB).
I usually use kingston hyperX of Corsair dominator, but i like to read reviews from users before buying if posible, http://www.newegg.com and cnet.com are good sources as u can read good and bad things based on experience.
I'd use a 850W PSU, also try to invest in a good case.
Jcschild
on Nov 10, 2009 at 2:53:59 pm
HI,
you need 3 drive minimum
do NOT buy Super talent as its XMP profiles are never right.
3 x 2gig is correct NOT 6x1gig.
buy an nvidia Card like a 260/285. Cuda is supported by Adobe and others.
Scott
ADK
liquid_snake_fox
on Nov 11, 2009 at 11:51:50 pm
hmmmm, now you make me think about CUDA, i was researching... but
GTX CUDA will only work on photoshop? or also has an impact on premiere and after effects? because i read after effects and premiere use the QUADRO CUDA cards...
I know ATI Stream is still green, but whats the future of this?
Also, i think i will buy the GA-EX58-UD3R MoBo...
Jcschild
on Nov 13, 2009 at 3:04:20 pm
Adobe takes advantage of the GPU in Photoshop, Premiere, and AE.
some plugs are CPU only others are GPU.
Adobe = nVidia for best performance.
