Asus P6T and the GTX 285
simon ellis
on May 25, 2009 at 3:58:00 pm
hi all,
i have two queations regarding the installation of the GTX 285 graphics card onto the asus P6T mobo. this is the first time i have built a system so pardon my stupidity Confused
1) do i need to connect the S/PDIF cable that comes with the 285? if so, i cannot work out where to connect the two single-pin connectors on the mobo. the P6T has a 4-1 connection for S/PDIF...?
2) following the DIY7 recipe, i used the antec nine hundred case, but the two 6pin power connections that go into the GTX almost prevent the case from closing as they stick out so much. is there a solution for this?
thanks in advance!
simon
