ASUS P6T question...?
Matt Gray
on May 21, 2009 at 6:40:51 am
On the P6T Deluxe V2, does a long vid card like the GTX 260 block the two forward facing SATA ports? Leaving the 4 others as the only available SATA ports?
If this is so, is there a work around if I want to use 3 SATA hard drives and 2 SATA DVD drives?
Thanks for the help!
Jcschild
Re: ASUS P6T question...?
on May 21, 2009 at 2:22:29 pm
HI,
even if it did there is no point to more than 1 DVD.
having a 2nd does you no good and it you do disk to disk its actually slower than doing it with 1 drive.
Scott
ADK
Matt Gray
on May 21, 2009 at 7:54:34 pm
Well, that is a matter of choice.
I would still like to know about the possible blockage of SATA ports on the P6t. So do you actually know about that or just have opinion related answers?
Jcschild
on May 21, 2009 at 9:55:31 pm
choice yes but pointless none the less.
but to answer the question
i got off my fat butt and walked to the build area the answer is no it wont be in the way
the sata ports have a parallel insert to the bottom of the case so they dont stick up. beside they would be ever so slightly to the side of a large video card
Matt Gray
on May 21, 2009 at 11:26:44 pm
Great to know! Thanks for the help!
