Adobe Premiere Pro 4 Showing a black screen while capturing
COW Forums : Tech Talk
on Feb 17, 2009 at 11:07:03 am
Hello All,
Following are my hardware and software details
H/W Details
system : HP XW 9400 (Work station)
Capture card : Matrox RT.X2
Camera : HDR-HC7(HDV 1080i).
S/W Details
Operating System : Windows Vista Enterprise - 64 bit
Adobe : CS4
Kindly correct me if the below mentioned steps are wrong. My intention is to use the Matrox card
1) Open Adobe Premier Pro
2) Click New project -
General tab
Action and Title Safe Area
Title Safe area - 20 % horizontal 20 % vertical
Action Safe area - 10 % horizontal 10 % vertical
Display Format - Timecode
Display Format - Audio Samples
Capture Format -> Matrox AVI
Configure ->
Video Capture Settings
Input Device - DV-1394
Input Source - Sony DV Device 1 (DISABLED) ok
Input Format - NTSC(DISABLED)
Input Aspect Ratio - 16:9(ENABLED)
capture Format - Native DV/HDV(DISABLED) Configure(Disabled)
Audio Capture Settings
Input Source - Sony DV Device 1 (DISABLED) Advanced Settings (DISABLED)
Capture Format - 16-bit tick of Show VU Meters
Capture Files
File Type - Stereo
Filename.Stereo1.wav - Channel 1-2 (D)
Filename.Stereo2.wav - None (D)
After giving filename and location I cilicked Ok button and the following screen appears
Sequence Presets - tab
Matrox - HD
720P@ 23.98 fps
General - tab
Editing mode - Matrox 720p @ 23.976
Timebase - 23.976 frames/second
Frame Size - 1280(disabled), horizontal 720(disabled), vertical 16:99 (just display)
Pixel Aspect Ratio - Square Pixels (1.0)
Fields - No Fields(Progresseive Scan) (Dsiabled)
Display Format - 24fps Timecode
Sample Rate - 48000Hz
Video Prviews
Preview File Format - 720p @ 23.98 fps
Codec [720@23.98 fps] Matrox-2i....
Maximum Bit Depth- no selection
Maximum Render Quality - no selection
After giving all the above details Iam taken to the main screen.
Using File - capture I tried to capture recorded videos in my camera.
When I tried to play vidoes on my camera using the play button the recorded video is been played on the Camera not on the Premeier Pro
I can fastforward,rewind, play slowly etc but i can't see anything on the Premeire Pro
Can anyone please help me in finding out a solution to this problem?
Thanks and Regards
© 2018 All Rights Reserved
