Mini DV Tapes for HD
tailgunner9
on Jan 31, 2009 at 2:19:50 am
Do regular Mini DV tapes for OK for HD or must you use the HD tapes??
John Q
Re: Mini DV Tapes for HD
on Feb 1, 2009 at 10:25:21 pm
We've used Sony premium miniDV tape in our FX1, before the HDV tape was available. It worked without dropouts. When we tried some TDK tape, we had a lot of dropout problems, which also resulted in loss of sync between the audio and video. You might be able to get away with using cheaper tape, but dropouts will cause you enough extra work and breaks in your video to more than make up for the extra cost of the tape.
