Is this a deal? If so, what should I upgrade for video editi
MACDSE
on Nov 21, 2008 at 10:54:25 pm
I am new here Surprised ops:
I am not sure if this is the right place to ask but I will give it a shot.
I saw a pc on ebay roughly 400 dollars give or take.
My question is, if you were on a budget, what would you upgrade on this?
I need a pc for video editing nothing too fancy and nothing over 10 minutes for youtube persay. I dont have a cam corder so I dont need anything for that. All I need is a pc that will handle and render some small 3d transitions on occassion. No real high resolution stuff videos will be rendered to 640 x 480. I hope I am making my self clear. I make boxing videos but not on any commercial level, just for fun with Sony Vegas.
Again, what would be the bare minimum you would recomend I upgrade?
Thank you for your time and remember I am on a budget.
Surprised ops:
Alex Cantu
Re: Is this a deal? If so, what should I upgrade for video editi
on Nov 24, 2008 at 4:47:16 pm
Hi
I'm not a fan of AMD, but it looks fine as it is. Use Vista 64 bit edition + Vegas 8 . Just add a second drive for system (200 Gb is ok).
In case u want to upgrade the video card you'd have to upgrade the power supply too... but this si completely optional.
Cheers.
Seaking
on Nov 25, 2008 at 1:14:32 pm
MACDSE: I am new here Surprised ops:
Surprised ops:
The only thing I see negative on this system is the "onboard" stuff.. video and audio on the motherboard, not seperate cards.. thusly the mobo / cpu takes all the load which may result in sub par work *if* you're capturing.. but if you're only converting video (not capturing), then just about anything will do.. but for captures, you'd want to avoid these all in one MoBos...
Best of luck!
