A solution for playing JVC camcorder(mod files) problems
yhcxhf
on Oct 24, 2008 at 5:32:59 am
A solution for playing JVC camcorder(mod files) problems!
Question 1: I recently purchased a JVC camcorder that records video as .MOD files. I can't seem to edit the files or play them on my PC. Is there a way to convert .MOD files to .MPG or something that works on my computer?"
Question 2: I have a video file off my JVC as well and wonted to play it on WMP so i changed the file extension from .MOD to .MPEG. Now the problem i have is that the video quality is poor. It?ˉs like the video cant keep up with the playing speed, lines drag when something moves. I know this quality is poor because it plays fine on cyberlink power dvd. Any help plz on how to fix the poor quality????
Question 3: I change the ext. mod to avi or mpg , and it works but the problem no sound at all.. .try to burn it into dvd, no luck, i try to burn it into vcd no luck also...
Introduction: .MOD files are Rolling Eyes JVC's implementation of MPEG-2 transport streams, similar to a VOB file on a DVD or the M2T files used on Sony hard drive camcorders.
Solution:
I actually just found a program called [url=http://www.aidownloading.com/mod-converter.html]Aiseesoft Mod Video Converter. This program will allow you to export your video(s) as .AVI,WMV,MP4,3GP files etc. Here?ˉs a brief overview of how to do it:
1. Install and run [url=http://www.aidownloading.com/download/mod-video-converter-276907.exe]Aiseesoft Mod Video Converter
2. Add files
3. Set output video format
4. Click the ?┬░Start?┬▒ button to start the conversion.
This tool also allows you to split,join,crop Mod/Tod files, it is very powerful.
I hope this helps, if anyone has a better method or a better software for doing this, please let me know!
yhcxhf
Re: A solution for playing JVC camcorder(mod files) problems
on Oct 25, 2008 at 4:22:39 am
Hoe it is useful for you!! Rolling Eyes
yhcxhf
Hope it is useful for you.
on Nov 3, 2008 at 1:50:36 pm
If you want to convert iTunes and other protected videos to MPEG,WMV or other video and audio formats you can choose [url=http://www.aidownloading.com/media-converter.html]Daniusoft Media Converter.
If you still want to watch other common video/audio even HD video on your portable video device you can choose [url=http://www.aidownloading.com/media-converter-pro.html]Daniusoft Media Converter Pro because Daniusoft Media Converter only support DRM audio and DRM video.
