help diagnosis this symptom
COW Forums : Tech Talk
Jack Laurie
on Oct 19, 2008 at 8:51:50 pm
I have a q6600 2gb ran with winxp with nvidia pny quadro fx 3000 agp. A small capacitor (other?) near the dvi connector side of the card broke off. The card works but,
every so often my monitor turns hazy white transluscent for 1/2 to a few hours. You can keep working if you can see well enought thru it. then it clears. Is this related to the broken component or something else someone has experienced before? if its clearly consistant with a broken capacitor (resistor?) what is likely going on?
© 2018 All Rights Reserved
