Finding: a DVD to iPod Converter at a discount
wolovely
on Sep 27, 2008 at 2:08:15 am
Just find the striking news: a kind of DVD to iPod Converter is on sale and only $19.
It can convert almost all kinds of DVD movies to MP4, H.264, MP3, M4A and AAC for your iPod Touch/Nano/Classic, iPhone, iPhone(3G) and Apple TV., then you can enjoy them anywhere and at any time.
Next, the step by step guide will show you how to use [url=http://www.aiseesoft.com/dvd-to-ipod-converter.html]Aiseesoft DVD to iPod Converter
Instruction: Install and run [url=http://www.aiseesoft.com/download/dvd-to-ipod-converter.exe]Aiseesoft DVD to iPod Converter
Step 1: Import DVD
Place the DVD into your DVD drive and click “Load DVD” button to load DVD.
Step 2: Video Settings
Select the output video format you need from the “Profile” drop-down list. Click “Settings” button to set your video and audio parameters.
Step 3: Start Conversion
Click “Start” button to start your conversion and it will be finished in a short while.
Tips:
1: You can also select Audio Track and Subtitle from their respectively drop-down list.
2: If you like the current image of the video you can use the “Snapshot” opinion. Just click the “Snapshot” button the image will be saved and you can click the “File” next to “Snapshot” button to open your picture. You can select the destination of the picture by clicking the “Preference” button. As default the captured image will be saved at:
your My DocumentsAiseesoft StudioSnapshot
3: If you want to merge the selected titles of chapters into one output file you can check the “merge into one file” option. As default the merged file is named after the first selected file (either a title or a chapter)
More tips:
1: Trim Movie
If you just want to convert a clip from your DVD movie, you can click the “Trim” button to open the Trim window, you can trim duration of the selected title or chapter by either dragging the Start Time and End Time sliders or setting the exact time in each corresponding field.
After you set the trimming time, the length of the captured clip will be shown in the Select Length box for your reference.
2. Movie Effect
If you want to change the original video effect, you can click the Effect icon to set the video brightness, contrast, saturation and audio volume. You can also set the special effect for your movie to cater to your need.
3. Video Crop
With Aiseesoft DVD to iPod Converter you can remove the black edges around your movie video by checking the “Crop” option and customize your movie.
There are three methods available to crop your video:
Method 1: Crop by selecting a crop mode
Select a crop mode in the crop mode drop-down list and click OK to save the crop. There are six pre-set crop modes for your choice: No Crop, Cut off Top and Bottom black edges, Cut off Top black edge, Cut off Bottom black edge, Cut off Left and Right black edges, Cut off All black edges.
Method 2: Crop by adjusting the crop frame
The crop frame is the yellow line around the movie video. There are eight small adjustment boxes on the crop frame. Each adjustment box allows you to crop the movie video from a different position. To crop your movie video, you can just move your mouse cursor to an adjustment box and drag the crop frame.
Method 3: Crop by setting the crop values
There are four crop values on the lower right part of the crop window: Top, Bottom, Left and Right. You can set each value to crop your movie video, and the crop frame will move accordingly.
Before you start to crop your movie video, you can select an output aspect ratio from the Zoom list. There are four choices available: Full screen, Keep original, 16:9 and 4:3. After you select an output aspect ratio and finish the crop, the result can be previewed in the Preview window of the program main interface
