Software for HD video conversion
freeflying
on Aug 7, 2008 at 5:16:26 am
Xilisoft HD Video Converter is a magic HD converter program for all High-Definition video lovers! It gives you all authority for video/audio converting. Either you want to convert between various video and audio formats, or extract pictures or audios from videos, or even create video from static pictures, this HD video editing software will obediently do the job for you with high efficiency.
Xilisoft HD Video Converter also provides output formats compatible with your portable devices, including iPod, iPhone, Apple TV, PSP/PS3, Xbox, Zune, iRiver, mobile phones and so on.
The following is a brief introduction on how to utilize this HD video editing software to personalize video files.
Part One: Basic operations of the software
1, start Xilisoft HD Video Converter
Import files, folder or pictures for conversion are all provided. This HD converter supports nearly all popular video and audio formats. Folder is for importing files in batch. The pictures can also be added for creating video, which includes static pictures. The properties of imported files can be shown up if you need. And the sequence of listed files can be changed by drag-drop for you to decide the priority of files for conversion.
2, select output format
Output format can be selected when you choose a profile for one or multiple files. And the brief parameters of each profile can be generally set in the “Profile Settings” panel. Parameters might be different according to the profile.
For HD converter’s professional users, who have strict need for the output files, this HD video editing software provides “Advanced Profile Settings”, where tens of exact parameters can be set. The modified profile can be applied to all imported files in list, and can be saved as customized profile for future use.
The destination folder for output files can be changed, and the folder can be opened for browse.
3, set multiple profiles
You can set different profiles, including the customized, for different files. Even more, Xilisoft HD Video Converter supports setting diverse profiles for output. That means you can set multiple different output formats at the same time for a single file. And the conversion will be done in consequence.
Part Two: Other functions of this software
Provide Bitrate Calculator, a powerful application to calculate video bitrate, with file size and audio bitrate selected.
Allow checking over information of source files.
Feature several alternative skins.
Support multi-language including Simplified Chinese, Japanese, Detush and English.
Part Three: Conclusion
Generally speaking, this HD video editing software is both efficient and easy-to-handle. It can meet diverse needs of different users. If this HD video editing software also gets the function of direct outputting files to compatible devices, it will be perfect. May the company has already taken this into consideration and is developing it in that direction. What we should do is just waiting and watching.
