RTX.100 vs DV Storm Comparison
COW Forums : Tech Talk
Gary Bettan
on Aug 27, 2002 at 6:35:40 pm
The following was posted by George Lin
He owns both a DV Storm and an RTX.100. I have re-posted it here with his permission. Thanx, george!
The RT.X100 has real-time scan and capture.
The RT.X100 offers real-time MPEG-2 out of the box. It also supports .m2v MPEG-2 export. Canopus (obviously feeling a lot of pressure from the RTX.100) has an offer for a free StormEncoder. It's free. The StormEncoder has better quality than hardware encoding of the RT.X100. Canopus SoftEncoder has better quality than the Ligos Encoder. Realtime encoding to MPEG2 and MPEG1 are supported as is the option to have a program stream or separate elementary streams.
The RT.X100 has frame accurate DV insert editing. DVStorm claims to have frame accurate DV insert editing but apparently, most people can't get it to work.
The RT.X100 has TurboDV which delivers very-fast DV output rendering when you exceed the real-time capabilities of the card. The DV Storm doesn't have a fancy name for their very fast rendering but it's effectively the same.
The RT.X100 has a realtime DV AVI file output. The DVStorm's realtime DV output is only via firewire.
The RT.X100 offers a huge selection of real-time, fully customizable 3D effects. The effects can be applied as filters or as transitions. However, only two streams are supported. The DVStorm includes the RT3D which delivers only a select group of 3D effects. The DVStorm also include Xplode Basics which offers a good selection of real-time, fully customizable 3D effects. Storm's 3D effects allow for multiple video streams, up to 6 in some of them. Also, Xplode supports the importing of 3D models and props generated from Lightwave. Xplode is also fully anti-aliased and support the overscan region properly.
The RT.X100 delivers field-based speed change which looks substantially better than competing products. The Storm delivers field-based speed change that looks substantially better than competing products and they've had this feature for about 2 years now.
The RT.X100 delivers time-lapse capture and has integrated support for Premiere's stop motion capture. The Storm does not have time-lapse cpature.
The RT.X100 delivers advanced real-time chroma/luma-keying. It offers spill suppression, shadow preservation and has a "Auto" button that makes chroma-keying easy for anyone. The Storm also has real-time chroma/luma-keying with an "auto" button to make keying easy for anyone. The Storm support masking of just the area of interest whereas the RT.X100 must key the whole frame.
The RT.X100 delivers advanced color correction with an "Auto" button that simplifies the process. It also supports a Final Cut Pro-like three-way color correction no other PC-based product offers. The Storm does color correction in native YUV color space of DV whereas the RT.X100 works in RGB. The Storm also includes the vectorscope and waveform scope to assist in colour correction. Also, the Storm has the option to only colour correct a portion of the screen.
The RT.X100 has what-you-see-is-what-you-get (WYSIWYG) support for third-party products like Adobe After Effects, NewTek LightWave and 3D Studio Max. The RT.X100 offers real-time support for a variety of character generation tools including Premiere Titling, Title Express, Title Motion, Title Deko and more. DV Storm also includes WYSIWYG for After Effects and supports Premiere Titling, Title Deko, (basically anything that's supported by Premiere.) It does not have WYSIWYG for Lightwave and 3D Studio Max.
The RT.X100 accelerates batch exporting in a variety of standard formats including Real and Windows Media formats. DVStorm also includes export of Real and Windows Media formats (without the need for Procoder.)
There is no 4GB file limit for files captured with the RT.X100 unlike the DVStorm. And if you do long form editing, this is an unnecessary pain in the rear that Canopus should have fixed long time ago. As a consolation, Canopus has a seamless capture feature where it breaks the files into 4G chunks as you capture.
The DVStorm offers 5 real-time streams whereas the RT.X100 is only capable of 2 video streams.
The DVStorm offers over 20 real-time graphics layers whereas the RT.X100 is only capapble of 2 graphics layers.
The realtime stackability of the DVStorm scales linearly with CPU power. The RT.X100 currently does not significantly scale with CPU.
The realtime 3D stackability of the DVStorm scales with the video card processing power. The RT.X100 3D is currently limited to the onboard 3D processor.
RT.X100 uses a rendered Quicktime clip for their "film effect". DVStorm has a true, realtime "old movie/film" effect which is truely randomly generated and very customizable.
RT.X100 is lower in cost than the DVStorm.
RT.X100 requires more CPU power than the DVStorm when 3D is excluded. When 3D is included, the DVStorm requires a fairly high-end video card to keep most of it's 3D effects realtime for more than 10s.
The video codec quality on the DVStorm is better than RT.X100, thus the quality of say a photo montage looks better with the DVStorm.
RT.X100 emulates all the standard Premiere transitions. DVStorm does not do the native Premiere transitions in realtime. It adds it's own "Canopus" specific transitions which are realtime.
RT.X100 uses Adobe Premiere exclusively. Canopus has CanopusEdit in addition to Adobe Premiere. Canopus supports VideoVegas in some of their newer products, but currently not the Storm. (If only Canopus would just switch to VV3.)
RT.X100 has an excellent Matrox forum where Matrox staff answer just about every question. Canopus can't seem to figure out what they want to do with their forum and posts on the Canopus forum are not guaranteed to get a response from Canopus if the forum did actually exist. (As of last week, there is no "official Canopus forum")
Customer satisfaction appears to be increasing with Matrox whereas it would appear to me, to be decreasing with Canopus.
Matrox is Canadian and Canopus is Japanese.
The Electronic Mailbox 800 323-2325
We Are The Desk Top Video Editing & Production Experts
All DTV purchases come with our exclusive 30 day customer assurance program and FREE Tech Support
© 2018 All Rights Reserved
