Good IPhone Video Converter For you to Use!
informationspy
on Apr 22, 2008 at 7:35:12 am
How to fast and easily convert AVI to iPhone, MPEG to iPhone, WMV to iPhone MP4, MPEG-4 Video etc. with the excellent quality? The following tutorial is to tell you a general method to solve these problems.
1. Download Xilisoft iPhone Video Converter. Install and run it.
2. Load files to be converted
Run Xilisoft iPhone Video Converter. Click 'Add' button or 'File' >'Add' to add the video or audio files that you want to convert.
3. Set output profile.
Select ‘Profile to choose a format you want to convert the files to.
Tip: Besides the output files provided by the software, you can also customize your own profiles according to needs.
Step 1: Add and select the files you want to convert, select target format in 'Profile' list, and then modify parameters on the right panel.
Step 2: After the modification, you can save the modified 'Profile' in a customized way of clicking the 'Save As' button on the main interface.
4. Preview source files.
iPhone Video Converter supports a preview window on the right bottom of the main interface to view the selected file.
Select the file you want to view in the program list and click 'Play' button to play it. You can also use the 'Previous', 'Pause', 'Stop' and 'Next' buttons to set the playback position.
Tip: This function is only for previewing the source file.
5. Convert
Then click the 'Encode' button to start the conversion.
6. View the result
After the conversion, click the 'Open' button at the bottom of the main interface to browse the output files.
Tip: If the output file is iPhone format, you only need to click the 'Open' button, and copy or drag the required files into your iTunes.
