How to configure the best and easiest Raid setup ?
bavariabub
on Apr 15, 2008 at 1:52:05 am
After spending many days on this subject and reading hundreds of posts I find that I am not alone in needing more detailed help on this to set up my new workstation.
Can you please post a detailed step by step or link on setting up Raid 0 (hardware or software and why) with seperate drive for OS and also another drive for storage for the Asus P5W DH and XP pro
Thanks Steve
Grady Knight
Re: How to configure the best and easiest Raid setup ?
on Apr 22, 2008 at 7:31:51 am
I have had a RAID-0 array for about five years now. I use a High Point Technologies raid card and can hook up 6 drives but still only use 2. If you want to go that way I will help you as much as I can.
Pretty straight forward, install the card, install drives add drivers and software, set up array then format all your drives as one.
I still have my OS, XP Pro on a seperate drive.
bavariabub
Raid 0
on Apr 23, 2008 at 3:55:59 am
I was also thinking of a Raid controller card.
Can you tell me which card you are using and if it fast enough for AVCHD (h.264) editing......(using 8MB / 7500rpm HDD striped 0 )
Thanks Bav
