Disk Defragment for RAID?
ChrisFMA
on Mar 16, 2008 at 3:36:54 pm
Can someone recommend a program to defrag RAID config drives?
I don't think Windows Disk Defragmenter is capable.
jeffcss
Re: Disk Defragment for RAID?
on Apr 14, 2008 at 6:06:19 am
One of my clients uses PerfectDisk on a server with a large RAID array. Seems to work OK.
Why do you say the Windows Disk Defrag isn't capable. I know it is slow, but you could let it run over night. Or does it just not work?
ChrisFMA
Defrag for RAID
on Apr 15, 2008 at 2:36:26 am
The windows version just seems to hang and not do anything.
jeffcss
on Apr 15, 2008 at 3:51:11 am
Interesting.
The other product is Diskeeper. Both of these companies have less expensive, "home" versions. Might want to check the specs to make sure that the version you get does large drives.
Tom O'Farrell
on Apr 26, 2008 at 7:58:14 pm
Windows defragmenter will not work when the drive has a paging file.
I have a raid setup that defragments fine when I temporarily get rid of the paging file.
ChrisFMA
on Jun 24, 2008 at 4:05:33 am
how do i get rid of the paging file?
