Video Editing System
tailgunner9
on Mar 2, 2008 at 9:04:13 pm
Going to get a Quad Core E6600, so does it matter if you have one or 2 video cards SLI, to get the the BEST video editing and then Best after edit to put onto a DVD???? Thanks for Help Guys.
jeffcss
Re: Video Editing System
on Apr 14, 2008 at 6:12:57 am
You posted over a month ago and just joined but in case you are still wondering, most video editing software does not run better with better/faster video cards and none support SLI. After Effects and some other programs will use the video card processor during rendering, but even then a mid-range video card is just as good as high-end card. Check to see the recommended video card for the NLE you are going to use.
tailgunner9
on Apr 24, 2008 at 10:49:27 pm
Thanks for reply on video card. Now another question if I may.
Is 2 hard drives better than one 500Gb for video editing and burning to DVD??
jeffcss
on Apr 25, 2008 at 6:24:21 am
Video editing is CPU, RAM and hard drive intensive. So you want the drive where you are editing to be different than the O/S and the faster and usually the bigger the better. So two 500 GB drives in RAID 0 gives you both fast and big.
HOWEVER, do NOT store ANYTHING you want to keep on a RAID 0 array. If either drive fails, you lose ALL the data on BOTH drives. You have twice the odds of this happening with two drives.
Store your original work and anything you may need to make changes some where else. If this is a business, store it in two different places.
The actual burning of the DVD is NOT resource intensive. You don't burn until all the editing/rendering has been done.
Hope this helps!
