Hard drive help with older mobo...
steveparkhill
on Feb 16, 2008 at 3:49:50 pm
Hey Folks,
I searched first for answers, but just couldn't find apples to apples answers.
I have an Asus P4C 800 Deluxe MoBo w/P4 3.00 GHz cpu, xp home - upgrading to xp pro, running a RT.x100 Extreme Pro w/Premier Pro 7.0.
The mobo has 2 SATA connectors and a separate Promise SATA raid on board(2 drive capacity).
My goal would be to use a Maxtor Diamondmax Plus 9 SATA 150 200gig drive (which I already own) as the boot drive.
Now for the raid setup...
Sata vs. sata 2, rpm, and cache size vs availability.
Question 1: will a sata-300 work on a mobo sata-150? I read that the sata-300 has a jumper which, left in place, will allow the drive to work in the place of the 150. Is this true and without consequence? Ques 1a: cable the same?
Question 2: What could bite me with the purchase of the 2 drives for the SATA RAID? Do I lose or gain anything going with the more available SATA-300 7200rpm 16mb drives with the jumper in place? or do I need to stay with a SATA-150 drive? Q2a: About rpm and cache... I can get a WD Raptor 10,000rpm 16mb 150GB. But then I'm limited to 300gb total as a video raid. (and they are comparatively expensive at $170ea) or I see SATA-300 320 or400GB 7200rpm 16mb with many more brand/model choices. This gives me more total GB space. And as I research it, SATA drives lose their speed beyond 1/2 full, which seems to make total capacity very important.
On the cache issue, there are some 8mb for both 150 and 300. lots of 16mb and a couple of 32mb choices. Real time pros/cons?
Please help me to not stick my hand in the blender when making this purchase decision!
Edit: And a question about dual channel ram... I have 1 gig currently (2 512 sticks). I know ram should be matched. But does that mean per channel or total? Should I replace my current with two matched 1 gig sticks or keep my existing and buy another 2 matched 512 sticks? Thanks.
Thanks in advance,
Steve
steveparkhill
Re: Hard drive help with older mobo...
on Feb 18, 2008 at 1:02:47 pm
Wow, did I get an eyeful over at the Matrox forums.
So let me re-ask my drive questions after waking up to how out of the loop I've become...
With my mobo and Matrox card, what drives and drive set up should I upgrade to?
Thanks for any help!
Steve
Alex Cantu
on Feb 21, 2008 at 10:17:03 pm
A1: The cable is the same for SATA I and II. And yes, SATA II disks have a jumper to limit data tranfar to 150 Gbs (or at least seagate disks, which are those i work with)
A2: you wont see much difference unless u work HDV or uncompressed SD files... and honestly that's out of P4 league. But two SATA 300 7200 rpm work fine for HDV.
A3: about the ram, u can have two 512 and two 1GB dimms. SO if u have 4 slots this is the best option
steveparkhill
on Feb 24, 2008 at 4:02:57 pm
Chippo,
Thanks a lot! I was mostly sure I could put the 512's in the 2nd channel for a total of 3gig. But "mostly sure" has gotten my in trouble too many times!
Steve
