Cooling My Computer
Rick Sullivan
Cooling My Computer
on Jan 22, 2008 at 3:45:28 pm
I want to put my computer and hard drives in a closet or on the other side of a wall to reduce noise. What are the best products and/or designs for cooling a hot, noisy, super computer?
3.0GB Dual Xeons/4GB Ram/Raids and three external hard drives. I use Matrox Axio w/Premiere Pro
Gary Bettan
Re: Cooling My Computer
on Jan 29, 2008 at 3:27:23 pm
be very careful here. Air flow is critical. Make sure you have adequate airflow to dissipate the heat.
GAry
erlend
on Jan 31, 2008 at 1:03:32 pm
Fit a 360x120 radiator with three 120mm fans, blowing air from the cabinet out through the radiator. Should be OK for dual Xeons, if you do not overclock them. I have one quad-core at 3,6Ghz, and a 240x120 radiator. With slow speed fans (1000rpm) the load temp of the cores is 55-60 degrees Celsius. Put quality waterblocks on the Xeons, and a quality water pump. Use 1/2" tubing. Few things beat water when it comes to effective cooling.
