Building a system. Need help with a powersupply
williemon
on Jan 2, 2008 at 4:01:33 am
Im building a system.
Asus P5LD2 Rev 2
Intell core 2 duo 4300 I think. 1.8G dual core
2 GB Corsair memory 800mhz (2 1G sticks DDR2)
PNY Nvida Quadra FX 1300
Im using my current systems drives. 1 dvd rw, 1 cdrw, floppy, 2 7200 rpm ide HDs.
What do yall think about this system? I use P Studio 9 or studio 10 on my old system and will still use it on the new.
Questions:
I found 800 mhz DDR2 instead of 400 mhz. Would this be a problem?
What wattage of power supply should I look for? Around 430 or closer to 500? Any brands better than others? Should I stay away from the less than 40.00 PS? Im maxed out on cash but I need what I need. A very good, quiet lower priced PS that wont cause issues when I editing.
Thanks all. First post but I have learned a lot on this site.
Fisherman
Re: Building a system. Need help with a powersupply
on Jan 16, 2008 at 11:39:58 pm
Did you find a solution?
