HD to standard converting software anyone??
greenough
on Dec 28, 2007 at 2:37:46 am
I was wandering if theres a possible peice of software that allows me to downscale from HD to standard. I bought a HD video camera even though i can change the settings to standard i recorded some stuff i cant get back and i need to get it in standard format.
monsta75
Re: HD to standard converting software anyone??
on Jan 5, 2008 at 4:09:07 am
You can try using VoltaicHD for PC which will allow you to convert your AVCHD clip to AVI, which you can then use in Movie Maker and then downgrade the published video via one of the available Profiles.
Johnson H. Nguyen
on Mar 20, 2008 at 8:44:14 pm
hey greengouh did this method work out for you? why in the first place would you need to have HD degraded to standard though?
