A/V out of sync on standalone DVD player; in sync on PC
Perjan
on Dec 11, 2007 at 1:40:30 pm
I'm having a strange sync problem making my own movie and burn it to DVD. Audio and Video are out of sync in my normal DVD player (the one connected to my TV set). When I play the DVD in my PC, it is in sync.
The original move is ripped to AVI DV from the DVD of a DVD camera using Pinnacle Trex v1.5.0. I've edited the movie using Windows movie maker v2.1.
I wrote the movie to a .wmv file. After that, I created DVD files on my harddisk (AUDIO_TS empty, VIDEO_TS*.BUP, *.IFO *.BUP) using WINAVI9.0. After that, I burned the files on DVD. I tried both WINAVI9.0 and Intervideo WINDVD Creator v2.0 for burning. Same results. In WINDVD creator, I tried both MP2 and AC3 audio encoding. I even tried two different DVD burners.
In all cases:
When playing the VIDEO_TS.IFO from harddisk, it's in sync.
When playing the DVD on my PC, it's in sync
When playing the DVD on my regular DVD player, it is out of sync.
What can be the reason for this?
How can i solve it?
Here is the output of GSPot on the wmv en the IFO file:
[code:1:b867cb147b]
FILE_NAME It's a wonderfull world final.wmv
FILE_NAME_WITH_PATH My DocumentsMy VideosIt's a wonderfull world final.wmv
FILE_SIZE 234,117,284
CONT_AUDIO_STREAM_COUNT 1
CONT_BASETYPE ASF (.WMA/.WMV)
CONT_BYTES_MISSING
CONT_INTERLEAVE_ALIGN
CONT_INTERLEAVE_PRELOAD
CONT_INTERLEAVE_TIME
CONT_SUBTYPE
CONT_TOTAL_BITRATE 0
VIDEO_ASPECT_CONVERT_AVI1
VIDEO_ASPECT_CONVERT_AVI2
VIDEO_ASPECT_CONVERT_CVD1
VIDEO_ASPECT_CONVERT_CVD2
VIDEO_ASPECT_CONVERT_DVD1
VIDEO_ASPECT_CONVERT_DVD2
VIDEO_ASPECT_CONVERT_SVCD1
VIDEO_ASPECT_CONVERT_SVCD2
VIDEO_ASPECT_CONVERT_VCD1
VIDEO_ASPECT_CONVERT_VCD2
VIDEO_ASPECT_SOURCE_MATCH
VIDEO_ASPECT_TYPE_NTSC
VIDEO_ASPECT_TYPE_PAL
VIDEO_BITRATE 1512
VIDEO_CODEC_NAME WMP v9 (VC-1 Simple/Main)
VIDEO_CODEC_STATUS Codec Status Undetermined
VIDEO_CODEC_TYPE WMV3
VIDEO_DAR
VIDEO_DURATION 21:08.539
VIDEO_FIELDS_PER_SEC
VIDEO_FRAME_COUNT
VIDEO_FRAMES_PER_SEC
VIDEO_H264
VIDEO_MPEG2
VIDEO_MPEG2_3X2
VIDEO_MPEG2_BFF
VIDEO_MPEG2_I_L
VIDEO_MPEG2_PPF
VIDEO_MPEG2_PROG
VIDEO_MPEG2_TFF
VIDEO_MPEG4
VIDEO_MPEG4_BVOP
VIDEO_MPEG4_GMC
VIDEO_MPEG4_NVOP
VIDEO_MPEG4_QPEL
VIDEO_PAR
VIDEO_PICS_PER_SEC
VIDEO_QF
VIDEO_SAR 1.250
VIDEO_SIZE_X 720
VIDEO_SIZE_Y 576
AUDIO_BITRATE 160
AUDIO_BITRATE_TYPE CBR
AUDIO_CHANNEL_COUNT 2
AUDIO_CODEC 0x0161 (WMA v2)
AUDIO_CODEC_STATUS Codec Status Undetermined
AUDIO_MPEG_STREAM_ID 0x01
AUDIO_MPEG_SUBSTREAM_ID
AUDIO_SAMPLE_RATE 44100
FILE_NAME VTS_01_1.VOB
FILE_NAME_WITH_PATH My DocumentsMy VideosDVD_01_1VIDEO_TSVTS_01_1.VOB
FILE_SIZE 1,071,927,296
CONT_BASETYPE MPEG (.MPG/.MPEG/.VOB)
CONT_BYTES_MISSING
CONT_SUBTYPE
CONT_TOTAL_BITRATE 8259
VIDEO_ASPECT_CONVERT_AVI1 Resize to 787 x 576 (Use +/- for other target sizes)
VIDEO_ASPECT_CONVERT_AVI2 Crop off any non-picture areas, if req'd
VIDEO_ASPECT_CONVERT_CVD1 Resize to 360 x 576 ( w:[1/2] h:[1/1] )
VIDEO_ASPECT_CONVERT_CVD2 Trim 4 from each side for 352 x 576
VIDEO_ASPECT_CONVERT_DVD1 No resize req'd
VIDEO_ASPECT_CONVERT_DVD2 No cropping req'd
VIDEO_ASPECT_CONVERT_SVCD1 Resize to 480 x 576 ( w:[2/3] h:[1/1] )
VIDEO_ASPECT_CONVERT_SVCD2 No cropping req'd
VIDEO_ASPECT_CONVERT_VCD1 Resize to 360 x 288 ( w:[1/2] h:[1/2] )
VIDEO_ASPECT_CONVERT_VCD2 Trim 4 from each side for 352 x 288
VIDEO_ASPECT_SOURCE_MATCH DVD
VIDEO_ASPECT_TYPE_PAL PAL
VIDEO_BITRATE 6597
VIDEO_CODEC_NAME MPEG-2
VIDEO_CODEC_STATUS Codec(s) are Installed
VIDEO_CODEC_TYPE MPEG2
VIDEO_DAR 1.333
VIDEO_DURATION 20:45.040
VIDEO_FRAME_COUNT 31126
VIDEO_FRAMES_PER_SEC 25.000
VIDEO_H264
VIDEO_MPEG2 MPEG-2
VIDEO_MPEG2_3X2
VIDEO_MPEG2_BFF
VIDEO_MPEG2_I_L
VIDEO_MPEG2_PPF
VIDEO_MPEG2_PROG Prog
VIDEO_MPEG2_TFF
VIDEO_MPEG4
VIDEO_MPEG4_BVOP
VIDEO_MPEG4_GMC
VIDEO_MPEG4_NVOP
VIDEO_MPEG4_QPEL
VIDEO_PAR 1.067
VIDEO_PICS_PER_SEC 25.000
VIDEO_QF 0.636
VIDEO_SAR 1.250
VIDEO_SIZE_X 720
VIDEO_SIZE_Y 576
AUDIO_BITRATE 128
AUDIO_CODEC MPEG-1 Layer 2
AUDIO_CODEC_STATUS Codec(s) are Installed
AUDIO_MPEG_STREAM_ID 0xc0
AUDIO_SAMPLE_RATE 48000
[/code:1:b867cb147b]
Please help!
Thanx,
Perjan
