jiggly title problem when importing into Premiere from AE
squeakyjim
on Nov 16, 2007 at 5:24:43 pm
Hi, I've recently compiled a video in Premiere CS3 using still images and video clips. I used After Effects CS3 to create titles that blur in and out as an effect.
Here is the issue: whether I render the titles from AE or directly import the AE files into the Premiere timeline, the titles tend to render out jiggling up and down when they should be staying still after blurring in. This happens even with the least amount of compression, and meanwhile all of the clips and panning images are perfectly fine. What's going wrong?
