Split/ join/ subtitle/ crop/ trim/ effect the file while rip
blueberry ds
on Oct 22, 2007 at 9:04:53 am
Nowadays rip DVDs is a common activity performed by many software programs, even many advanced computer users don't know how to improve output quality or customize DVD file. Ripping DVDs by split/ join/ subtitle/ crop/ trim/ effect the video files will help you customize DVD file as you like and get the best conversion results. This guide will show you how to use [url=http://www.daniusoft.com/dvd-ripper.html]Daniusoft DVD Ripper to rip DVD in an easiest way and explain how to split/ join/ subtitle/ crop/ trim/ effect the video files while conversion.
Part one: How to convert DVD to iPhone/ iPod/ PSP/ Zune/ Apple TV/ Phone/ Xbox/ Zen/ AVI/ MPEG in an easiest and common way.
1 Download [url=http://www.daniusoft.com/dvd-ripper.html]Daniusoft DVD Ripper, Install and Run it.
2 Insert your DVD disc into your DVD-Rom (Ensure that you have sufficient space on hard drive to store the DVD). Click “Load DVD” button to add the DVD file. You can also click “Load File” to add DVD/IFO from your hard disk.
3 This software can convert DVD to all popular video formats such as MPEG-4, AVI, WMV, VOB, 3GP, FLV, etc. Click the “Format” drop down list to select a format.
You can just select “Lossless DVD Copy (*.vob)” to copy DVD to computer in 1:1 lossless quality.
Note: Choose the audio formats if you want to rip DVD audio track to MP3, WMA, WAV and so on. So that you can enjoy DVD audio on iPod Nano, iPod Shuffle, Creative Zen, Zune and some other MP3 players.
4 If you want to convert DVD by default settings, just click “Start” button to convert. It is the easiest and common way to convert with only three steps.
Note: You can click the “Settings” button next to the format field to open the Settings window and set video resolution, frame rate, bit rate, encoder, etc. See the figure below:
Part Two: Split/ join/ subtitle the video files to convert.
1 Split or Join: It will help you to convert any clips or join several clips as you want.
One: A DVD may have multiple titles and each title contains one or more chapters. After a DVD movie is loaded, its contents will be listed. Click “+” to show the chapters in a title. Then you can preview this clips and to select the chapters or titles you want to convert.
Choose the “Merge into one file”, the clips which you like will convert into a new video. By this way, you can split a DVD to several clips or join any clips you want into a new video. Maybe after this, a new amazing video comes out.
Note: If you have selected a title, then you need not to select the chapters in it. As the title contains the chapters in it, don’t choose to convert twice.
2 Change the subtitles; write new ones as you like.
After you choose the clips, every clips has its default title which you can rewrite or select no subtitle.
Part Three: crop/ trim/ effect the video files to improve the quality.
1 Crop – Cut off the black edge of your DVD movie to let you enjoy your movie in full screen by click the “Crop”button.
Move your mouse cursor to a box on the frame around the video, and drag the frame to crop your video. Or you can choose a crop option from “No Crop, Cut off top and bottom black edges, Cut off top black edge, Cut off bottom black edge, Cut off left and right black edges and Cut off all black edges”.
2 Trim – As you have selected the clips to convert, here you can trim any segment of your clips to convert by click the “Trim” button.
Drag the button under the Preview window to select segment you want.
3 Effect- Set the Video Effects: Brightness, Contrast, Saturation and adjust the volume to modulate the effect. All the progress you can see preview clearly.
jump tracy
Re: Split/ join/ subtitle/ crop/ trim/ effect the file while rip
on Nov 16, 2007 at 10:17:56 am
en,look like very cool,value to try. Very Happy
blueberry ds
Great!
on Dec 3, 2007 at 12:03:44 pm
tracyjump: en,look like very cool,value to try. Very Happy
Confused
Hope you enjoy it.
Nowadays, it has a new version which could convert DVD in a pretty good quality.
If you have any questions about ripping DVD, feel free to post here.
sharker_2008
on Dec 10, 2007 at 6:45:12 am
Are this software compatible with windows vista?
blueberry ds
Have a try
on Dec 12, 2007 at 11:41:37 am
sharker_2008: Are this software compatible with windows vista?
Yes.
This DVD Ripper could support all the popular windows: 2000, XP, Vista.
sharker_2008
Re: Have a try
on Dec 25, 2007 at 6:12:15 am
blueberry287:
Yes.
thank you , i will try it now!
Merry Xmas
blueberry ds
Enjoy
on Jan 3, 2008 at 5:37:33 am
Very Happy
Hope you really enjoy it!
The converter support Creative Zen V plus now!
Johnson H. Nguyen
on Mar 20, 2008 at 8:46:54 pm
Is this program capable with Vista and let's say I wanted to add subtitles to one of my videos, could this program actually perform it? I don't see a drop box or signature where I can add it in the pictures.
jump tracy
on Apr 29, 2008 at 3:44:08 am
I have own it because it's really a poweful DVD rip software which can rip your DVD movie in a super fast DVD Ripping speed and lots of powerful functions.It satisfied me. Very Happy
gycafesor
on Jun 4, 2008 at 5:47:51 am
it's what I finding...
by the way, is it a good dvd ripper?
jump tracy
on Sep 8, 2008 at 7:59:17 am
Can Daniusoft DVD Ripper rip some of the chapters of my DVD to a single one?
sharker_2008
on Oct 14, 2008 at 9:25:28 am
I am kind of a factory ripper computer so I like to rip DVDs off my computer and send them off. But AOA DVD ripper can't rip portected DVDs so is there a power DVD prgram where it rips portected DVDs?
gycafesor
on Nov 8, 2008 at 6:49:33 am
I think a good dvd ripper not only rip protected DVD, but also has powerful DVD edit function, such as the upgraded [url=http://www.convert-video-dvd.com/dvd-ripper.html#115]dvd ripper I google.
