Capture error
classicph
Capture error
on Oct 20, 2007 at 12:12:36 am
So, I build a PC per Gary's recommendation.
Installed CS3, Was trying to capture and got the famous error:reset the VCR
Q: should I proceed and Install Matrox RTX2 or, should I try to fix the problem first?
Evan Newsome
Re: Capture error
on Oct 20, 2007 at 2:31:47 am
i dont have cs3 but did you set up CS3 'capture settings to your specific hardware?
classicph
capture error
on Oct 20, 2007 at 1:28:34 pm
Well, PC has a1394 Firewire, a did not see any other option to set up.
I am ready to install RTx-2, but want to try without and it did not work.
Shul i proceed with instalation ot try fix the problem first?
Evan Newsome
Re: Capture error
on Oct 20, 2007 at 5:38:43 pm
and what is the firewire connected to?? (camera? converter box?)
that is the hardware you need to tell CS3 is connected.
classicph
Re: Capture error
on Oct 20, 2007 at 10:16:01 pm
Firewire connected to panasonic AG DV-2500, once I could conrtol it,but no image and no sound, rest of the time give this favorite message: reset my VCR
Evan Newsome
Re: Capture error
on Oct 21, 2007 at 2:29:10 am
well go back and verify under 'device control' your camera is set.
(I don't have CS3, I have 2.0 , but mine is located on the 'settings' tab, seen when you are trying to capture.
Adobe could of moved it when they changed their version.
classicph
Re: Capture error
on Oct 21, 2007 at 1:04:57 pm
It is on the list and selected, but still no respond.
Q: should I proceed with RTx2 installation or try to fix this first?
