Canon HV20 - Shuttle Don't Connect
MichuR
on Oct 18, 2007 at 1:04:17 pm
Hi to all
I just got the Canon HV20 took some video and ran to my computer to download it. No luck. I loaded the Canon CD and then realised it's only for stills. My computer couldn't even see the camera. After many frustrating attempts I deleted the Canon files/drivers and then the computer could control the camera, but still, no video. I found on the internet there should be some drivers there that weren't, so I copied them accordingly. Nada. I don't even feel I am advancing as sometimes the computer sees/controls the camera sometimes it doesn't. In any case, still no video.
Please help!
Configuration:
Computer: Shuttle SN25P
MoBo/Chipset: 939 NVidia 4 Ultra
CPU: AMD 64 X2 Dual 4600+ 2,41GHz
RAM: 1 GB
Graphic Card: Radeon X1600
HDD: IDE 80GB + SATA 500GB
OS: Win XP SP2
John Q
Re: Canon HV20 - Shuttle Don't Connect
on Oct 19, 2007 at 5:46:23 am
You need a video editing application that understands HDV to do the capture. You might try Premiere Elements. I have a Sony HC3 and Premiere Pro 2, which edits the video, but doesn't understand where the breaks are, so I use HDV Split to do the capture. You can download HDV Split for free from:
http://strony.aster.pl/paviko/hdvsplit.htm
You'll still need an application to edit the video.
MichuR
On my way. Not there yet.
on Oct 20, 2007 at 6:03:47 pm
Hi thanks for the info.
I can capture the DV content, but not HDV. In fact in Premiere the HDV option is greyed out when opening a new project.
I used HDVSplit and that produces a m2t file that I play in VLC Media Player and in Windows Media Player (jumpy, though) but I can't import it into Premiere (it doesn't recognize m2t as a compatible file).
I must be missing a codec or driver. Could you help me out telling me what to do and where to get the codec? Maybe I need another application to transform the m2t into something Premiere understands. Of course, what I don't want is something that lowers the HDV quality. If that was the case I would just as well record in DV.
John Q
on Oct 21, 2007 at 2:06:52 am
Premiere Pro will import and edit HDV since version 1.5.1 and should read m2t files directly. Of course, you have to open an HDV project. What version are you running?
