FRAME CROPPING IN EDITING HD IN DV MODE PREMIERE CS3
Rob Burrows
on Sep 19, 2007 at 2:09:39 pm
I am using a SONY HDR HC7 with good results when inputting & outputting via iLink (firewire) on HD only.
When I edit a DV project in PREMIERE CS3 the source clip appears ok, but once on the timeline it converts to severe cropping (about middle 1/3 of picture showing). In other words, conversion to DV crops and I have no other way of rendering quality DV from HD source.
I have tried forcing recognition of HD Anamorphic and other pre-settings using the INTERPRET FOOTAGE command, to no avail.
I have a feeling this may be a bug (I have used the recent update patch). Does anyone have any solution?
Many thanks.
Rob Rolling Eyes
Rob Burrows
TO CLARIFY:
on Sep 19, 2007 at 5:48:32 pm
This probelm occurs when working in a STANDARD DEFINITION PROJECT using HIGH DEFINITION FOOTAGE which BECOMES CROPPED.
Ta,
Rob
Rob Burrows
CONVERSION TO SD / DV SOLVED - BUT NOT ON COMPUTER
on Oct 3, 2007 at 10:26:13 am
I have resolved this by using the camera to convert/output DV - but I have no conversion system on the computer yet - which would be useful. I will start a new link on conversion to standard def.
Rob
