Guide - Burn Free Torrent Movie to DVD for Home DVD Player
bryantsinger
on Sep 12, 2007 at 5:40:33 am
This article will help you how to download free movie/anime video and burn them onto DVD with DVD menus so that you can play it on your home DVD player.
This article contains two parts:
1. How to Download Torrent Movies/anime video?
2. How to Burn the movies and anime videos onto DVD?
Download Torrent Movies/Anime Video
BitTorrent is a file-sharing tool that lets you download content directly from other users’ computers. Many people have downloaded movies and songs using bitTorrent while some people still have questions about how to use it. In fact, it is fairly easy to use bitTorrent to download videos. Here’s a simple 3-step guide to help you connect to other BitTorrent users to download files:
Firstly, Get a BitTorrent Client
Download uTorrent from http://www.utorrent.com/ and install it.
First you need a BitTorrent client, a program that will enable you to connect to other users and thereby download the files you want to.
Then, Find a Torrent
Now that you have a BitTorrent client installed, you’ll want to find torrents you like and download them. For that you have to visit a BitTorrent directory or use a BitTorrent search engine like Torrentz. For example, open http://www.torrentz.com in your browser and search for anything (Naruto for instance). If you see something you like, follow the link and download the .torrent file from the site.
And, Start the Download
Once downloaded, double-click the file and it will open and start downloading in your BitTorrent client. uTorrent will ask you to specify a location to save the file. That’s all. Not too complicated, is it?
How to Put torrent videos onto DVD?
with [url=http://www.dvd-ripper-copy.com/video-to-dvd.html]Wondershare Video to DVD Burner, it takes five simple steps to organize video files to slideshows and burn them to DVD.
Step 1: Organize your slideshow
Click the 'Load file' button to load the video files you want to burn. Then drag & drop the loaded files from the Collections pane to the slideshow storyboard to start organize your slideshow. You can sort the order of the video files in a slideshow by drag them in the storyboard. Click the Add Slideshow button (the first button from the left above the storyboard).
Step 2: Apply Effects
Click the Effect tab and you will see all the available transitions in the Effect pane, to apply a transition, you can just drag and drop it to into the slideshow storyboard.
Step 3: Customize DVD menu (Optional)
Click the Menu tab to customize your DVD menu. There are different styles of built-in templates, frames and buttons for your choice. To apply a template, frame or button, you can just double click it. You can even add text, background music and background image to customize the menu.
Step 4 Preview your video slideshow(s)
Click the Preview tab to preview your slideshow project by click the preview control buttons. This step is to help you decide if everything is what you have expected. If not, you can go back to any of the previous steps to make changes to your project.
Step 5 Start Burning
After you finish the four steps above, click the Burn tab to prepare for burning your project. If you want o burn your project directly to the DVD disc you have inserted in your DVD-ROM, you can just select “DVD” in the “Burn to” field, specify a temp folder (used to save the generated temporary files), select your DVD drive and burning program (either built-in or your own burning application), select, select your TV Standard and output aspect ration, and click Start to burn your project.
If you just want to create DVD files or an ISO file for the current project, you can just select the “DVD Folder” or “ISO file” option, specify a folder to save them, and click Start to generate DVD files or ISO onto your computer.
vediason
Re: Guide - Burn Free Torrent Movie to DVD for Home DVD Player
on Sep 14, 2007 at 7:31:53 am
Great article
Thanks, bryantsinger
