HP-XW4300 SYstem
Yash
HP-XW4300 SYstem
by
on Aug 13, 2007 at 8:47:32 pm
Hello,
I have HP WinXP, 3.40GHz/2MB 800FSB Pentium 4 CPU,1GB(2x512MB)DDR2-533 ECC,FireGL V3100,160GB SATA 3Gb/s NCQ 7200, 300GB AV Drive.
I would like to run Martox RT.X2 with Adobe Premier 2. It installes perfect but when I try to load the software it gives me The error says something along the lines of "The hardware does not meet the minimum requirements...".
What would be cause of this error?
I will appreciate your quick response.
Yash
Evan Newsome
Re: HP-XW4300 SYstem
on Aug 14, 2007 at 2:06:59 am
Do you get the error when installing PP2.0 OR the drivers/software for the Matrox card?
did you call HP?
Look under system properties, make sure your CPU is set to it's fullest MHz (3.4MHz). if it is set correctly and it sees your 1GB...
see if there is a MOBO BIOS update. I am not sure what Adobe does to see if your computer meets min. specs.
Yash
XW-4300
by
on Aug 14, 2007 at 2:10:39 pm
PP2.0 installed successfully and my computer is working under the manufactures default settings. BIOS is up to date and working on 3.4GHZ speed. What could be problem I am thinking of RAM, what do you thing?
Yash
Evan Newsome
on Aug 14, 2007 at 10:42:45 pm
PP2.0 worked fine for me w/ 1gb, although I put a total of two in, to speed things up.
call adobe, the error must generate a log for tech support to see which item doesn't meet 'spec.'
Yash
XW-4300
by
on Aug 15, 2007 at 3:54:25 am
I also think 1 GB would be enough but my problem is I sold this unit to my customer overseas and now I am having this problem to solve it. What would be best bet to solve this issue.
Yash
Evan Newsome
on Aug 15, 2007 at 3:53:43 pm
well if the machine is not in front of you. not much you can do.
did you install everything or did he? if he did.. his problem. if you did.. you should of tested everything.. have him send it back
Yash
XW-4300
by
on Aug 15, 2007 at 4:05:22 pm
Okay,
Yash
