How-To:Convert DVD,AVI,MPEG,WMV,DivX to iPhone (Mac/Windows)
Roberta
on Aug 3, 2007 at 6:22:30 am
This guide will show how to rip DVD and convert DVD to iPhone video (H.264/MP4), convert video files (like AVI, MPEG, WMV, MOV, ASF, RM, RMVB, VOB, IFO, DVR-MS, FLV) to iPhone video for Mac OS X and Windows PC, And will also describe the iPhone video format information and related tips.
1. iPhone video format supported;
2. What iPhone conversion software you need;
3. How to convert DVD to iPhone (Windows);
4. How to convert video files to iPhone on Windows;
5. How to rip DVD to iPhone for Mac;
6. How to put video on iPhone (Mac OS X);
7. Sync converted movies/videos/music to iPhone.
1. What formats iPhone can play
1). iPhone Video formats supported: MPEG-4/H.264 up to 640x480 pixels, 1.5Mbps (MPEG-4 video supports videos up to 2.5Mbps), 30 frames per second, AAC-LC audio up to 48kHz, 160Kbps, stereo audio in .mp4, .m4v and .mov file.
Tip: 480x320 is the native resolution of the iPhone screen and this is the best video size to encode your videos to. The iPhone also accepts 640x480-pixel resolution video without the need to convert it but it will have to down-convert it to get it to fit on the screen. That’s just a waste of processing power. Much better to encode the video to the right resolution to start with and save as much battery power as you can.
2). iPhone audio formats supported: MP3, MP3 VBR, AAc, Audible, Apple Lossless, AIFF, and WAV from 20Hz to 20,000Hz.
2. What software you need
1). iPhone software: iTunes 7.3 or later.
2). iPhone Converter Suite: Includes both tools mentioned below.
DVD to iPhone Converter: From the program's name, you can learn it is able to move DVD movies to your iPhone.
iPhone Video Converter: Be dedicated to moving all popular video formats like WMV, AVI, MPEG, MOV, ASF, RM, RMVB, DVR-MS, FLV, VOB to iPhone.
Tip: Both Quicktime Player and iTunes can test the converted videos.
3. How to Rip Convert DVD to iPhone (Windows)
Install the [url=http://www.dvdtoiphone.net/software/iPhoneSuite_r38540.exe]DVD to iPhone software, start it up and click on 'Open DVD' icon if the DVD you wish to copy doesn't load in automatically. Browse for the DVD drive, click 'OK' button.
When DVD menu (like 'play', 'scene', 'set up') appears on the preview window, click on the 'play' link. After a while, 'Ready to record video' window is opened. If you would like to rip DVD movie using the default settings, just enter the output file name, choose the output quality and the start point and hit the 'Yes' icon to start copying. It is the easiest way.
Defalut profile for iPhone
Profile: iPhone (480x320) MPEG-4 Movie (.mp4);
Resize: Keep original aspect ratio;
Crop: No crop;
Output Folder: C:ConverterOutput;
Video Encoder: MPEG-4;
Video Bitrate: 1000kbps;
Frame Rate: 29.97 fps;
Video Size: 480x320 pixels;
Disable Video: No;
Audio Encoder: AAC (Advanced Audio Codec)'
Audio Bitrate: 56Kbps;
Sample Rate: 48000Hz;
Channels: Stereo;
Volume: 100%;
Disable Audio: No;
Language/Subtitle: DVD default.
If you want to choose other video codecs (such as H.264), other profiles (for iPod video, MP3) or check more parameters before ripping, just hit 'No' icon.
Set the subtitle and audio track (optional): Click 'Setting' Menu at the top of the main window, select the related options. You can also set this according to the DVD menu on the preview window.
Choose different target formats from 'Profile' entry: The iPhone software supports copying DVD to iPhone/iPod and ripping DVD audio to MP3.
Customize your profile: Let's take iPhone for example. Ensure the 'Profile' entry still says 'iPhone (480x320)', adjust various parameters from 'Audio/Video Output Settings' Window. Here, you can change video encoder to 'H.264'.
The final thing you need to do is to click on the 'Convert' button to rip.
Only need to rip a chapter or some DVD chapters? No problem. Click on the 'Batch' icon at the top of the main window, enable the check box for wanted chapter(s) and title(s).
After the first DVD to iPhone copying is done, load the result video file from your C:ConvertOutput folder into iTunes or QuickTime just to make sure it works correctly. If it works here, it should work on the iPhone. The steps to copy a DVD to an iPhone is just so easy!
4. How to convert iPhone video (H.264, MP4) and iPhone audio (MP3), MOV to iPhone, DivX to iPhone, Xvid to iPhone, AVI to iPhone, MPEG to iPhone, WMV to iPhone, DVR-MS to iPhone, RM to iPhone, RMVB to iPhone, ASF to iPhone, AVS to iPhone, MPG to iPhone and more.
Install the [url=http://www.iphonevideoconverter.com/]iPhone Converter software and start it up. Click on the 'Open file' to load into the movies/TV shows/video files you wish to convert. The program support almost all video formats as resources.
Supported Input Formats:
AVI: XviD, DivX, AVS;
MPEG video: MPG, M1v, M2p, M2v, Vob;
Windows Media video: Asf, Wmv, Asx, Wax,
Quicktime Video: MOV;
RealMedia: Rm, Rmvb;
Others: Flash FLV, Digital Video Recorder, DVR-MS.
Direct hit 'Convert' icon to begin to converting using the following default value.
Defalut profile for iPhone:
Disable Video: No;
Channels: Stereo;
Volume: 100%;
Disable Audio: No;
Certainly, you can also adjust video codecs (such as H.264), profiles (for iPod video, MP3) or check more parameters before converting.
When the converting process is completed, you’ll find the converted video file in your C:ConvertOutput folder. Load the result video file into iTunes or QuickTime just to make sure it works correctly. If it works here, it should work on the iPhone.
Now all you need to do is that Sync up your videos to iPhone using iTunes, and you should be able to watch your movies on the go with the nice 3.5-inch wide screen.
The steps for converting MPEG to iPhone, WMV to iPhone, RM to iPhone, AVI to iPhone, MOV to iPhone, ASF to iPhone, RMVB to iPhone, VOB to iPhone DVR-MS to iPhone, FLV to iPhone video is just so easy!
5. How to Convert Rip DVD to iPhone for Mac OS X
[url=http://www.dvdtoiphone.net/]DVD to iPhone Converter for Mac can not only rip and convert DVD to iPhone video format, but also convert DVD to iPhone audio formats like M4A, WAV and MP3 etc, on your Max directly.
Insert the DVD movie you'd like to rip into the DVD drive, Click "DVD" button to load your DVD, select the output format and set the optional parameters like audio track and subtitle, Hit 'Convert' to start the iPod DVD conversion process.
6. How to convert iPhone video for Mac OS X
[url=http://www.iphonevideoconverter.com/]iPhone Video Converter for Mac, a faultless iPhone video converter, can convert all popular audio and video files, such as AVI, MPEG, WMV, MP4, VOB, AAC, AC3, MP3, to the formats supported by iPhone/ iPod including MP4, M4A, MP3 etc.
Load your video files by click the 'Add' button, Set your the audio channels, video size and frame rate etc. or you can leave it to the default setting. Click the "Encode" button. Done!
7. Sync video/music to iPhone
You can sync media to iPhone easily with iTunes v7.3.
http://www.apple.com/itunes/download/
Connect iPhone to your computer via USB cable, drag your result videos to the list, then click on the 'File -> Sync iPhone'. That is it.
