Simple monitor output question
COW Forums : Tech Talk
on Jul 29, 2007 at 3:10:53 pm
From the Lagoon of Liquidspaceman...
Ok, I am trying to save some time. I don't want to render my project, I just want to play the time line and record it on a stand alone DVD burner. I use EdiusPro and I want to be able to view the time line on my tv, through the fire wire. Here is the setup... The fire wire is connected from the Stormbay to my DVD burner. From the Burner to the tv I have it hooked up using the rca cables. I know I have the correct connection from the burner to the tv as I can see the info on the tv. What do I need to set on my computer to be able to see my time line info?
...Liquidspaceman, over and out Shocked
© 2018 All Rights Reserved
