Is my system drive fast enough? Do you need a fast system d
fishquail
on Jul 25, 2007 at 11:01:31 pm
If my video and media are on a Fast RAID array then do i need a fast system drive?
Say I built one of the systems recommended on this page.
And I have a RAID array for my video - but my System drive is an older UltraDMA EIDE133 250g Maxtor. This system drive is testing at 51mb/s Read, and 26mb/s write. -According to Blackmagic disk speed check program.
A New SATA drive tests at 53 write and 43 read. So should i bother upgrading my system drive or stick with the older EIDE drive? Main Programs i use are Adobe After effects, premiere pro, Photoshop for uncompressed editing with blackmagic intensity.
Specs:
MB: Tyan K8WE
AMD Opteron 270 (dual)
4GB RAM.
Nvidia Quadro FX 560
Apple cinema Display 30'
4x500gb RAID array (2TB total) on Nvidia SATA motherboard controler.
Evan Newsome
Re: Is my system drive fast enough? Do you need a fast system d
on Jul 25, 2007 at 11:38:54 pm
the system drive doesn't need the 'speed'... just space for OS & programs.
some people love the idea of a 10 second boot up. I could care less.
your scratch & media drives need the speed.
heck, I use older IDE 133 drives in my RAID and get no dropped frames. Since they work for me, why buy new ones. (FYI I only do SD)
4GB is a bit too much memory for WinXP or has things changed?
2 terabyte? Shocked do you think that will be enough? Laughing
fishquail
on Jul 26, 2007 at 2:11:16 am
I have 4GB but only 2.75GB shows up in Windows XP pro right now - but i intend to eventually go 64-bit at some point at which i can utilize all of it i hope.
For me there is never enough space. No matter what i alwasy fill it up - but thats cause i make a living shooting event videos and commercials in HD.
Alex Cantu
on Aug 9, 2007 at 8:58:57 pm
Win XP can handle up to 4 GB of memory (including video and audio memory). So, depending on your video memory and dimm configuration WIN XP will only recognize part of the total (though BIOS will tell u that u have 4 GB of RAM), also win xp wont alocate more than 2 gb of memory to a single aplication.
