Enjoy FLV from YouTube and Google Video on your iPod
Micky1020
on Jul 11, 2007 at 2:40:09 am
FLV to iPod
This tutorial is to show you a step-by-step demonstration of converting the YouTube videos and Google videos, etc, and enjoying them on your iPod player.
First of all, we have to make it clear that the YouTube videos and Google videos streaming online are of the Flash Video file, or FLV.
What is FLV?
FLV, or Flash Live Video file, is a preferred file format that is designed for web playback, offering high rates of compression to deliver video over the Internet using Adobe Flash Player (formerly known as Macromedia Flash Player) version 6, 7, 8, or 9.
Note: Unlike other conversion tools, Moyea FLV to Video Converter will enable you to convert your particular FLV files into the proper video format for playback on your Apple iPod player without the need to install extra codecs or other additional system or third party components for some functionality.
Launch Moyea FLV to Video Converter
In order to finish this guide, please install the [url=http://www.flvsoft.com/flv_to_ipod/]Moyea program of FLV conversion.
Once Moyea FLV to Video Converter is installed, launch the converter program.
Add File
Click on the "Add" button on the tool bar and start from here to import FLV files into the program.
As Moyea FLV to Video Converter supports batch encoding by default, you can edit the file list by clicking the buttons upon the file list: click "Add" button to import the files you want to convert.
Crop the video and add watermark to the video
Click on "Crop" button and you can crop the size of the video to determine what content is to be shown:
You can also add a watermark to the output file by checking box for watermark.
If you select multiple files for conversion, you cannot crop size of the video, but you can still add the same watermark for all the files.
Change the Output Settings to Edit the Movie
Click "Settings" and you could start to adjust the settings of the FLV for your output to play on iPod. Select "MP4" in the "Export Type" and under the "Sub-type" pull-down, select "iPod":
You can also choose one existing output format profile provided by the program with "iPod Video", The profiles preset by the system in the field "Select a Profile" are the commonly used one. By default, the program has preset the frame size of 320*240 pixels for iPod player.
If you select multiple files at once, you should click the "Apply" button on the bottom-right corner to apply the adjustment you just made for the selected files.
Start conversion
Click "Convert" to start to convert the files in the file list to the output folder.
Transfer videos onto iPod
From this point, you can resort the proper audio and video manager to import the converted MPEG4 encoded movie into your iPod player, and you may watch movies and videos on iTunes or Quicktime Player.
