Enjoy FLV from YouTube and Google Video on your PSP
Micky1020
on Jul 9, 2007 at 2:56:04 am
FLV to PSP movie
This tutorial is to show you a step-by-step demonstration of converting videos downloaded from YouTube and Google Video, etc, and enjoying them on your Sony PSP.
First of all, we have to make it clear that the YouTube videos and Google videos communicating online are of the Flash Video file, or FLV file format.
What is FLV?
FLV, or Flash Live Video file, is a preferred file format that is designed for web playback, offering high rates of compression to deliver video over the Internet using Adobe Flash Player.
FLV content cannot be played back directly but must be embedded in (or linked from) an SWF file. You create (or download) a "container" SWF file from which to play the FLV file. The most common approach is to use an SWF file that functions as a media player with screen and playback controls. Notable users of the FLV format include YouTube, Google Video, Reuters.com, Yahoo! Video and MySpace.
Launch Moyea FLV to Video Converter
In order to finish this guide, please install the [url=http://www.flvsoft.com/flv_to_psp/]Moyea program of FLV conversion.
Once Moyea FLV to Video Converter is installed, launch the converter program.
Add File
Click on the "Add" button on the tool bar to import your target FLV files into the program, by following the instructions.
Crop the video and add watermark
Select a specific file and you can crop the video to determine what area of the video image is to be shown. And you can also add a watermark to the output file by checking box for watermark. This step is particularly important to instructors or conference presenters if they are to display their logo in the generated video.
Change the Output Settings
Click "Settings" and you could start to adjust the settings of the FLV for your output to play on Sony PSP. Select "MP4" in the "Export Type" and under the "Sub-type" item, select "PSP". You can also choose one existing output format profile provided by the program with "PSP Video", The profiles preset by the system in the field "Select a Profile" are the commonly used one.
If you select multiple files at once, you should click the "Apply" button on the bottom-right corner to apply the adjustment you just made for the selected files.
Start conversion
Click "Convert" to start to convert the files on the file list to the output folder.
Transfer the Converted Movies to Your PSP
There is an easy way to transfer your MPEG4 files on your hard disc to your PSP: Moyea PSP Video Manager, as a freeware, is a good choice for you.
Please visit [url=http://www.my-video-converter.com/psp_video_manager/]http://www.my-video-converter.com/psp_video_manager/to download the program. After installing the program, you can follow the screen instructions to complete importing your generated video into the PSP in a few clicks.
