Is this a correct build for Sony Vegas 7 & Premiere CS3
newby
on Jul 5, 2007 at 8:30:23 pm
My preference is to use Sony Vegas 7, is this a good or bad build? Would it be suitable if I chose to use Premiere CS3? Only interested in standard definition editing for home/wedding/family function vids. There will be effects but nothing to heavy. Thanks
Asus P5WDH Deluxe
2.6g E6700 dual core
ONBOARD SOUND - Not adding a sound card
3 harddrives
ASUS EAX1950PRO/HTDP/256M/A graphics card
firewire card
DAC-200 - to take care of capture of analogue & monitoring of timeline
I don't need a capture card do I?
Am I likely to run into any problems?
My inputs will be from a dv camera also analogue inputs.
I would like to monitor the timeline on a tv
Your help would be appreciated. Of course I am on a small budget and I have settled on this configuration so please don't confuse matters unless you think it is really necessary. My head is in a spin already.
Alex Cantu
Re: Is this a correct build for Sony Vegas 7 & Premiere CS3
on Jul 9, 2007 at 9:55:37 pm
It looks pretty good though u dont mention OS and RAM.
Avoid windows vista, windows xp pro will give u no problems, and use at least 1 GB RAM.
If u are going to use Vegas u can save some money using a cheaper video card (vegas has no use for it, premiere uses nvidia cards), if u like ati an X700 is enough, even gaming.
Im not familiar with DAC200, just be sure it is compatible with Vegas.
newby
on Jul 10, 2007 at 3:49:58 pm
Oh yes, windows xp pro it will be! 2gig ram is intended. So thank you for your response, it's all looking pretty positive.
Regarding the Dac-200, I have been told that this is a better option rather than worry about compatibility of capture cards. So I am told, the Dac-200 will work if you plugged it into your lawn mower! Fingers crossed!
Jon Oransky
on Jul 11, 2007 at 3:05:16 pm
you should be fine. the dac 200 will work fine with the firewire that is built on that motherboard.
- Jon
