Convert Flv to Zune with Moyea Flv to Video Converter Lite
COW Forums : Tech Talk
on Jul 4, 2007 at 4:08:12 am
What is Zune?
Zune is a portable digital media player from Microsoft. The first version, released in November, 2006, is about the size of a deck of playing cards and weighs 5.6 ounces. This is Microsoft's first digital music player and service.
The multimedia formats supported are MP3, WMA and unprotected AAC audio, but not protected AAC tunes from Apple. The Zune also handles H.263, MP4 and WMV video as well as JPEG images.
The Zune Player is your connection to the world of media and to the entertainment-loving people. In order to cater to people's diversified needs, Moyea, with its FLV to Video Converter Lite, is offering a series of solutions to convert the FLV files to the formats compatible with Zune, that is FLV to MP4, FLV to WMV, FLV to WMA, and FLV to AAC.
Moyea FLV to Video Converter Lite is an expert utility to convert FLV to the popular video and audio formats for playback at home or on the go. It supports FLV files by various codecs, including On2 VP6, H263, Nellymoser, etc, and could generate a series of audio and video files, such as AVI, MPEG, MP4, 3GP, MOV, WMV, DV, etc.
The program offers fine solutions to converting FLV files downloaded from video sharing sites to the formats compatible with the Zune player. To use this program to convert Flash Video files, you don't have to install additional plug-ins or other codecs. With the Lite version converter, you can just sit back and enjoy.
In order to finish this guide, please install the [url=]Moyea program of FLV conversion.
Launch Moyea FLV to Video Converter Lite and add files:
Principally, Moyea FLV to Video Converter Lite supports conversion in the batch mode; and you can add multiple files for conversion each time. Once the target FLV files are imported into the program, you can preview them in the preview panel of the interface.
Select the output format and change the audio and video settings
In the pull-down menu of "Export Type", choose "WMV" as the file format; and in the Sub-type, you could choose the proper device for your output file: WMV for PC, or WMV for Zune, etc.
Different sub-type will require different dimension or frame size of the video. Be default, the program has been preset the proper frame size for the most popular playback terminals.
Once you have set WMV as the output format, you can change the video and audio settings for the output file, including the codec, frame rate, bit rate, audio channel, etc.
Select the output directory and convert
When all the parameters are set, you can select a convenient output folder for you file in "Export To" and then click on "Convert".
© 2018 All Rights Reserved
